adithyab
Petalinux image generation
I am trying to generate images using petalinux. I see that the sizes of images generated is much smaller than the pre-built binaries.
Size of generated image.ub is 13.3mb whereas the one in pre-built is 48.8mb
Size of generated BOOT.BIN is 14.6mb whereas the one in pre-built is 27.6mb
Petalinux is version 2018.2 and bsp is xilinx-zcu102-v2018.2-final.bsp
Below are the steps used for generation of images
1.) petalinux-create --type project --template ZynqMP --name ZCU102 -s <path to bsp>
2.) petalinux-build
Should I be concerned that the images generated are smaller in size?Am I missing any step?
shabbirk
Hi @adithyab
Yes you are correct. Pre-built images are always bigger in size than the one generated after build. This is because pre-built image has additional files pre-compiled and bundled in it
Best Regards
Shabbir
gosha-z
At least, you've missed 'petalinux-config --get-hw-description' command
shabbirk
Hi @adithyab
Best Regards
Shabbir
adithyab
I have tried the below option
petalinux-config --get-hw-description=<path to folder with hdf>
Path was set to where the default system.hdf is stored. I still did not see any difference
adithyab
Hi @shabbirk
Thanks for the reply.
