palmercliff
Petalinux install does not add petalinux to the path
After running the Petalinux install on Ubuntu 16.04.3 64-bit workstation hosted on Virtualbox 5.1.2.2, I found that:
- The PETALINUX environment variable was not set
- no petalinux directories were added to the path
- the settings.sh script was not made executable
Can someone point out the errors I have made installing Petalinux?
The log of the installation is below:
cliff@cliff-VirtualBox:/opt/pkg/petalinux$ ./petalinux-v2018.2-final-installer.run /opt/pkg/petalinux
INFO: Checking installer checksum...
INFO: Extracting PetaLinux installer...
LICENSE AGREEMENTS
PetaLinux SDK contains software from a number of sources. Please review
the following licenses and indicate your acceptance of each to continue.
You do not have to accept the licenses, however if you do not then you may
not use PetaLinux SDK.
Use PgUp/PgDn to navigate the license viewer, and press 'q' to close
Press Enter to display the license agreements
Do you accept Xilinx End User License Agreement? [y/N] > y
Do you accept Webtalk Terms and Conditions? [y/N] > y
Do you accept Third Party End User License Agreement? [y/N] > y
INFO: Checking installation environment requirements...
INFO: Checking free disk space
INFO: Checking installed tools
INFO: Checking installed development libraries
INFO: Checking network and other services
INFO: Installing PetaLinux...
WARNING: PetaLinux installation directory: /opt/pkg/petalinux/. is not empty!
Please input "y" to continue to install PetaLinux in that directory?[n]y
INFO: Checking PetaLinux installer integrity...
INFO: Installing PetaLinux SDK to "/opt/pkg/petalinux/."
..........................................................................................................INFO: Installing aarch64 Yocto SDK to "/opt/pkg/petalinux/./components/yocto/source/aarch64"...
PetaLinux Extensible SDK installer version 2018.2
The directory "/opt/pkg/petalinux/components/yocto/source/aarch64" already contains a SDK for this architecture.
If you continue, existing files will be overwritten! Proceed[y/N]? Y
Extracting SDK................................done
Setting it up...
Extracting buildtools...
done
SDK has been successfully set up and is ready to be used.
Each time you wish to use the SDK in a new shell session, you need to source the environment setup script e.g.
$ . /opt/pkg/petalinux/components/yocto/source/aarch64/environment-setup-aarch64-xilinx-linux
INFO: Installing arm Yocto SDK to "/opt/pkg/petalinux/./components/yocto/source/arm"...
The directory "/opt/pkg/petalinux/components/yocto/source/arm" already contains a SDK for this architecture.
Extracting SDK..............................done
Setting it up...
done
$ . /opt/pkg/petalinux/components/yocto/source/arm/environment-setup-cortexa9hf-neon-xilinx-linux-gnueabi
INFO: Installing microblaze_full Yocto SDK to "/opt/pkg/petalinux/./components/yocto/source/microblaze_full"...
The directory "/opt/pkg/petalinux/components/yocto/source/microblaze_full" already contains a SDK for this architecture.
Extracting SDK.............................done
Setting it up...
done
$ . /opt/pkg/petalinux/components/yocto/source/microblaze_full/environment-setup-microblazeel-v10.0-bs-cmp-re-mh-div-xilinx-linux
INFO: Installing microblaze_lite Yocto SDK to "/opt/pkg/petalinux/./components/yocto/source/microblaze_lite"...
The directory "/opt/pkg/petalinux/components/yocto/source/microblaze_lite" already contains a SDK for this architecture.
Setting it up...
done
$ . /opt/pkg/petalinux/components/yocto/source/microblaze_lite/environment-setup-microblazeel-v10.0-bs-cmp-re-ml-xilinx-linux
INFO: PetaLinux SDK has been installed to /opt/pkg/petalinux/.
cliff@cliff-VirtualBox:/opt/pkg/petalinux$ echo $PETALINUX
( PETALINUX is not defined)
cliff@cliff-VirtualBox:/opt/pkg/petalinux$ ./settings.sh
bash: ./settings.sh: Permission denied
cliff@cliff-VirtualBox:/opt/pkg/petalinux$ chmod 775 settings.sh
PetaLinux environment set to '/opt/pkg/petalinux'
( PETALINUX is still not defined)
cliff@cliff-VirtualBox:/opt/pkg/petalinux$ echo $PATH
/home/cliff/bin:/home/cliff/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
(PATH does not contain any petalinux directories)
watari
Hi @palmercliff
Would you try to the following command ?
$ source <your petalinux install directory>/settings.sh
Also I sugges to use bash as shell, if you use petalinux.
Best regards,
watari
Hi @palmercliff
Best regards,
sandeepg
This path is just an example you can install on any local storage where you have read and write permissions.
I would suggest follow this my recommendation is to have a version specific directories when you have multiple versions installed.
$ sudo chown -R <user>:<group> /opt
$ mkdir -p /opt/Xilinx/PetaLinux/2018.2
$ ./petalinux-v2018.2-final-installer.run /opt/Xilinx/PetaLinux/2018.2
Sandeep
palmercliff
Thanks - your suggestions made the install work.
palmercliff
Thanks!
