Petalinux installation error on ubuntu VM
I am trying to install petalinux installer petalinux-v2019.1-final-installer.run on an ubuntu Virtual Machine as a normal user (not root). I have downloaded the pre-required packages metioned in UG1144 (v2019.1) (Petalinux installation guide).
However I still get this error below:
INFO: Checking installation environment requirements...
awk: read error (Bad address)
Please refer to the PetaLinux Tools Installation Guide.
Check the troubleshooting guide at the end of that manual, and if you are
unable to resolve the issue please contact customer support with file:
   /home/aj/Desktop/package/petalinux_installation_log
./petalinux-v2019.1-final-installer.run: line 140: /tmp/tmp.RyDQQuCamY/petalinux-env-check: No such file or directory
ERROR: Failed to extract Petalinux installer...
Could anyone help me to resolve this issue?
Hi @anjuman_degirum,
These errors are due to missing gawk packages on Ubuntu. We already have a CR to fix the missing information in 2019.1 UG1144 page 11(Quick Installation of Packages section)
Here is the right packages you need to install.
$ sudo apt-get install -y python gawk gcc git make net-tools libncurses5-dev tftpd zlib1g:i386 libssl-dev flex bison libselinux1 gnupg wget diffstat chrpath socat xterm autoconf libtool tar unzip texinfo zlib1g-dev gcc-multilib build-essential libsdl1.2-dev libglib2.0-dev screen pax gzip
Are you using Ubuntu-18.04 or 16.04?
Sandeep
Sandeep
Yes, it worked after attempting to install all packages in table 2 on UG1144 (v2019.1). Your command does the same I believe.
I am using Ubuntu 19.04, will that be a problem in the future? It has install correctly I believe.
Hi @anjuman_degirum ,
Yes Ubuntu-19.04 is problem for longterm as PetaLinux is generated using Yocto eSDK. Yocto community supports only 18.04 https://www.yoctoproject.org/docs/2.6.1/ref-manual/ref-manual.html#detailed-supported-distros and usually its only Ubuntu LTS versions are supported where 19.04 is not LTS.
Sandeep
