Observer ngrubaugh
Petalinux-package creating download.bit file?
I am currently trying to build the final boot.bin file to run petalinux on an FPGA and I have successfully run through petalinux-build. Now I just need to run the petalinux-package command to generate the boot.bin and uImage right? I ran:
petalinux-package --boot --format MCS --fpga path/to/bit --u-boot --kernel
WARNING: Auto detecting MMI file with HDF
INFO: Creating download.bit
INFO: Output download.bit: /home/folder/Petalinux_Proj2/images/linux/download.bit
ERROR: offset of bitstream "/home/folder/Petalinux_Proj2/images/linux/download.bit" is not specified.
2 questions:
1. Why is it creating a .bit file and not the specified .mcs file?
2. What is the offset of bitstream error message refering to?
Re: Petalinux-package creating download.bit file?
@ngrubaugh
What version of petalinux are you using?
Are you trying to generate MCS file or boot.bin file?
Generate Boot Image for MicroBlaze
1. Execute the following command to generate MCS boot file for MicroBlaze.
$ petalinux-package --boot --fpga <FPGA bitstream> --u-boot --kernel
It will generate boot.mcs in your working directory and it will be copied to the <proj>/images/linux/
directory. With the above command, the MCS file contains fpga bit, fs-boot, u-boot and kernel image image.ub.
2. Command to generate .mcs file with fs-boot and fpga only:
3. Command to generate .mcs file with fpga, fs-boot and u-boot:
If you would like to generate the boot.bin for Zynq  use the below command
$ petalinux-package --boot --fsbl <FSBL image> --fpga <FPGA bitstream> --u-boot
-Achutha
Observer ngrubaugh
@achutha,
I am using Petalinux 2015.2 along with Vivado 2015.2 tools. I have followed the steps outlined in UG1144 exactly in regards to the petalinux-package command to create the MCS file for a Microblaze, as you outlined as well, but still receive the error in my original message.
@ngrubaugh
Please share the hdf file so that i can verify the details.
-Achutha
Observer ngrubaugh
@achutha,
I included both .hdf files that were located in the SDK folder. I did try running through the petalinux tools with both but received the same error both times.
Visitor andrei_hres
Hi ngrubaugh!
I have same problem, have you resolved it?
Observer ngrubaugh
@andrei_hres :
If I recall correctly the .MCS file wasn't being generated because of the bitstream error I was getting, so they were related to each other. The petalinux-package command requries you to specify the flash size if you are going to be writing to the flash because it can't correctly figure out the size itself. So you just need to add the "--flash-size" command with the correct MB specified.
Visitor andrei_hres
Hi.
I have found that need define correct offset for files and every thing works. Like this:
petalinux-package --boot \
--format MCS \
--force \
--fpga images/linux/htg_v7_g3.bit \
--offset 0x000000 \
--fsbl images/linux/fs-boot.elf \
--u-boot images/linux/u-boot.elf \
--offset 0x800000 \
--kernel images/linux/image.elf \
--offset 0xA00000 \
--flash-size 128 \
--flash-intf BPIx16 \
--output firmware_test_01.mcs
Without offset definition I get error like in the first post.
Observer ngrubaugh
@andrei_hres
Ah, yeah that would do it as well. I remember defining those within the petalinux tools themselves.
Glad you figured it out!
Observer adrian.n
Hi andrei_hres,
Where did you find documentation for the correct offsets? I have the same problem as ngrubaugh when trying to build a bootable .bit file for a Genesys2 board. When I try explicitly defining the petalinux-package commands as in your post, I get the following error:
ERROR: [Writecfgmem 68-3] Bitstream at address 0x00800000 conflicts with bitstream at address 0x00000000.
I am guessing this is because the offsets are wrong, but I can't find information in either UG1144 or UG1157 on what these offsets should be.
