Anonymous
Not applicable
Petalinux problem was transplanted with a soft microblaze from v7FPGA
MicroBlaze, a soft core with V7FPGA, is expected to port the petalinux operating system.Check the ug1144 manual and learn that Microblzae soft core under vivado needs to be set up.Chip data is introduced as follows: 1Microblaze is set to linux-mmu mode;Provide external storage controller;3 dual-channel clock interruption;4 serial port interrupt;Use FLASH memory chips.
The following questions are available, and I hope they can help me:
How to set up 2,3,4,5 items of chip data when generating microblaze's IP core configuration under the vivado tool?
2 do data and instruction caches need to be set during IP kernel configuration?Do you need to add cached IP cores to your setup?
3 under petalinux, after the. HDF matches the petalinux project, it will enter the configuration hardware information interface. How to configure?
Thank you for your attention
Re: Petalinux problem was transplanted with a soft microblaze from v7FPGA
steps 2,3,4 and 5 are done in the Vivado IPI tool. If you are using a Xilinx development board, then you can use the Automation tools
to drag and drop, the Linear flash into the BD, and this will look after the pinout for you:
For all other IP, this can be added via the IP catalog in Vivado. For example:
For the Microblaze configuration, double click on the Microblaze in IPI and use the select configuration drop down to select the
linux with MMU:
Once you are happy with the HW design, then Generate Block Design, Create HDL wrapper, Generate Bitstream, then File -> Export -> Export Hardware (include bit). This will create the HDF
Then to create the project in Petalinux and config with HDF:
petalinux-create -t project --template microblaze -n microblaze_linux
cd microblaze_linux
petalinux-config --get-hw-description=<path to HDF>
petalinux-build
cd images/linux
petalinux-package --boot --fpga <name of your bitfile>.bit --uboot
linux with MMU:
cd microblaze_linux
petalinux-build
cd images/linux
