Visitor gordienkoa1
Petalinux spidev problem
Hello!
I'm working with a board zc702.
I have a problem with the spi cadence device driver. I need to run SPI (slave mode) from the user space. The top petalinux - 2016.4
I have been struggling with this for 2 weeks already. I'm in complete despair.
I reread all kinds of topics and guides and topics on this forum, but I can not find a solution.
My connection scheme:
I just hooked spi0 and spi1 through EMIO and pulled everything out
SPI_SS_I I have fed from a logical "one" (some kind of bug).
I exported the design and on a virtual machine with ubuntu added hardware to the petalinux build project.
I connect the paths to installed petalinux and sdk (I forgot to tell you I do not know in linux how to register these paths in bashrc, therefore I enter them every time)
# path to configuration files
source ~ / Programs / opt / pkg / petalinux / settings.sh
source ~ / Programs / opt / SDK / 2016.4 / settings64.sh
I create a project petalinux from the downloaded from the site xilinx bsp:
cd ~ / Programs /
petalinux-create -t project -s ./xilinx-zc702-v2016.4-final1.bsp
I go to this project:
cd ~ / Programs / xilinx-zc702-2016.4
I copy the folder with hardware that I exported from the vivado to the current project
cp -r ../hw ./
configure it hardware
there is a menuconfig in it I do not do anything right away
petalinux-config --get-hw-description hw/
configure the kernel
petalinux-config -c kernel
appears menuconfig
I go to device drivers - >> spi support and turn on the mode user mode device driver support
then go to the folder ./project-spec/meta-user/recipes-kernel/linux/linux-xlnx and open the file user_2017-12-14-11-20-00.cfg in it I see that SPIDEV is added.
I read on the forum that I need after this to configure the device tree
apparently from previous versions that something has changed, the structure of the files has become another previously referred to as subsystems, now there is no such folder. Device tree is located in several places, I only change ./components/plnx_workspace/device-tree-generation/
I change only system_top.dts, adding a spi1 device.
I run the build
petalinux-build
next I do the packaging necessary files
petalinux-package --boot --force --format BIN --fsbl ./images/linux/zynq_fsbl.elf --fpga ./images/linux/system_wrapper.bit --u-boot
received files image.ub and BOOT.BIN write to the SD card, insert the SD card into zc702 and boot
I expect to see a spidev in / dev /, but there's nothing there
It is extremely important for me to access the spi device as a slave, because In our system, the exchange between the main processor and zynq is performed by spi
I ask the help of the community, tk. I repeat that I despaired of finding an answer.
Forgive my English is in the research stage, I used google translate.
Re: Petalinux spidev problem
To program SPI devices on MIO, you will indeed need to add them to the Linux device tree so PetaLinux knows how to handle them. In my example, I only emulated the Zynq with QEMU, so I am not sure if/how it would run on real hardware.
One important thing is that your Cadence SPI driver won't work with EMIO. This driver is meant to interface with SPI devices connected to IO in the PS. This is probably why you are not seeing a spi-dev device.
To interface with SPI devices/ports from the PL you might want to have a look at http://www.wiki.xilinx.com/Linux+SPI+Driver.
I have not used this driver. I am still working on getting Linux configured to communicate with the PL over DMA.
I do not know what language you are in, but I hope this translates well over Google.
Visitor gordienkoa1
17.1.1 Features
Each SPI controller is configured and controlled independently, They include the following features:
Four wire bus – MOSI, MISO, SCLK, and SS
° up to 3 slave selects for master mode
Full-duplex operation offers simultaneous receive and transmit
32-bit register programming via APB slave interface
Memory mapped read/write data ports for Rx/Tx FIFOs (byte-wide)
° 128-byte read and 128-byte write FIFOs
° Programmable FIFO thresholds status and interrupts
Master I/O mode
° Manual and auto start transmission of data
° Manual and auto slave select (SS) mode
° Slave select signals can be connected directly to slave devices or expanded externally
° Programmable SS and MOSI delays
Slave I/O mode
° Programmable start detection mode
Multi-master I/O Capable
° Drives I/O buffers into 3-state if controller is not enabled
° Generates a Mode Failure interrupt when another master is detected
50 MHz SCLK clock frequency when I/O signals are routed to the MIO pins
° 25 MHz SCLK when the I/O signals are routed via the EMIO interface to the PL pins
Programmable clock phase and polarity (CPHA, CPOL)
Programmable interrupt-driven device or poll status
this is an excerpt from ug585 it says that spi can obviously be output via EMIO, but its speed will be less.
Or is it only the capabilities of the "Hardware" Cadence spi itself, and not the driver for it?
I'm confused
Visitor gordienkoa1
17.1.1 Features
• Four wire bus – MOSI, MISO, SCLK, and SS
• Full-duplex operation offers simultaneous receive and transmit
• 32-bit register programming via APB slave interface
• Memory mapped read/write data ports for Rx/Tx FIFOs (byte-wide)
• Master I/O mode
• Slave I/O mode
• Multi-master I/O Capable
• 50 MHz SCLK clock frequency when I/O signals are routed to the MIO pins
• Programmable clock phase and polarity (CPHA, CPOL)
• Programmable interrupt-driven device or poll status
this is from TRM ug 585 on ZYNQ.
I'm confused
