e.friel
Petalinux u-boot development
My understanding of customising u-boot, kernel etc for petalinux is that you download or clone the corresponding git repo, compile and build and then add it into the project directory. However I wasn't aware of the additional steps of creating a patch and also the need to create the custom receipe for it and it isnt on the petalinux manuals. Can someone explain the proper workflow for development or guide me to somewhere that has practical examples?
shirilt
Hi @e.friel
In case you don't want to create patches and tinker with bbappend files, you can point Petalinux to use external sources for the repos you wish to customize (u-boot, linux-xlnx, etc.). The steps to do this are outlined on p. 107 of https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug1144-petalinux-tools-reference-guide.pdf
Best,
Shiril
stephenm
You can create your u-boot patch against the same version of Petalinux. For example:
git diff xilinx-v2019.1 > 0001_patch_description.patch
Copy this to recipes-bsp/u-boot/files
Then update the bbappend to use this
SRC_URI_append += " file://path to p oatch.patch"
e.friel
@stephenm
I created the patch, updated the bbappend file, rebuilt petalinux (petalinux-build) however getting an error: "ERROR: Function failed: do_compile"
The build recognises the new environment and updates the environment variables but fails to rebuild.
Notable error messages:
ERROR: u-boot-xlnx-v2017.01-xilinx-v2017.4+gitAUTOINC+5fa7d2ed06-r0 do_compile: oe_runmake failed
ERROR: Task (/media/emmet/587b2d62-fa69-4edc-9884-5cf59b035e55/petalinux/components/yocto/source/arm/layers/meta-xilinx/recipes-bsp/u-boot/u-boot-xlnx_2017.01.bb:do_compile) failed with exit code '1'
stephenm
Have you tested that the mods you made to u-boot will compile.
See the steps here to manually compile
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841722/ZCU102+Image+creation+in+OSL+flow
e.friel
@stephenm
I copied the patch into /home/admin2/embeddedLinux/zyboBoard/project-spec/meta-user/recipes-bsp/u-boot/files directory.
Changed the bbappend file to point to the patch:
SRC_URI_append = " file://001_zybo_uboot.patch"
FILESEXTRAPATHS_prepend := "${THISDIR}/files:"
Cleaned the environment and rebuilt the u-boot. Getting a do_configure error, it seems it is still searching for platform-top.h:
| install: cannot stat '/home/admin2/embeddedLinux/zyboBoard/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.4+gitAUTOINC+5fa7d2ed06-r0/platform-top.h': No such file or directory
In the config file: /zyboBoard/project-spec/meta-plnx-generated/recipes-bsp/u-boot/configs/config.cfg it is pointing to the target (platform-top.h):
CONFIG_SYS_CONFIG_NAME="platform-top"
I took it out and compiled with many errors
shirilt
Hi @e.friel
Best,
Shiril
e.friel
@shirilt
Thanks for your help.
e.friel
For anyone who is building from external sources, the manual doesnt specify that you need to point petalinux to your new u-boot configuration file as it is still using the prebuilt one.
petalinux-config --> u-boot configuration --> u-boot config --> Change it to other
Enter your new u-boot config target underneath
DO NOT SPECIFY THE PATH TO THE FILE. SPECIFY THE FILENAME ONLY
