Petalinux v2018.2 Installation failure
I am installing petalinux v2018.2 in virtual box. I had installed all required libraries & packages which are given UG1144. But while installing I am getting the below error:
Error: You are missing the following system tools required by petalinux
-patch
But, I am not understanding which patch it is asking to install. I am attching the snapshot of the error as well.
Please suggest me to come out of this problem.
Jeetesh
Re: Petalinux v2018.2 Installation failure
Hi @jeetesh140790,
Can you provide the file petalinux_installation_log mentioned in the log?
Florent
