Petalinux without sources from Git
Is it possible to use petalinux without depending on the sources on the git server? Like fetching the sources just for the first time and then using them until another "fetch" command, not automatically.
My purpose is that I just don't like the file structure of the current petalinux projects. Sometimes I need to edit the sources but all of them are under some "git" prefixed folders; additionally I cannot make sure if my modifications will be saved or will be overwritten by a fetch.
Dosto
Tags (2)
Hi @f.m.dostoevsky-the-embedder
If you dont want to fetch source codes always then better change the configuration to pick the source codes from local repository, so that it will not fetch from GitHub.
Please follow below build steps for External source using petalinux:
1. petalinux-config and go to -> Linux Components Selection  ---> linux-kernel (ext-local-src)
                External linux-kernel local source settings  --->/aravind_working_dir/source_code/my_xlnx (EXternal  linux-kernel local source path)
2. Go to -> Auto Config Settings and select Specify a manual device tree include directory and enter the path to the new kernel include directory.
  Auto Config Settings  ---> [*] Specify a manual device tree include directory
        (/aravind_working_dir/source_code/my_xlnx/arch/arm64/boot/dts/include) Manual device tree include directory
3.  Save and exit petalinux-config
4.  petalinux-build
Thanks & regards
Aravind
4.  petalinux-build
Thanks & regards
Aravind
Xilinx provides prebuilt images with every software release and additionally Targeted Reference Designs.
If you are looking for more control over your sources, then you can use the Out of Tree Builds, see Chapter 9:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug1144-petalinux-tools-reference-guide.pdf
If you want to build a linux image, without Petalinux, then you can use the OSL flow covered in the wiki:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841722/ZCU102+Image+creation+in+OSL+flow
Re:
This worked great for me btw when I had the same question
