patocarr
Petalinux won't boot over JTAG
Hi folks,
  I'm chasing an issue with this custom RFSoC-based board that somehow doesn't boot over JTAG, but boots and works fine from QSPI. I'm positive this JTAG boot has worked in the past year, so the hardware seems to be fine. I'm now using Vivado and Petalinux 2020.2.
  The QSPI memory is programmed over JTAG using either Vivado hardware manager or from the program_flash script from Vitis. The board also has an eMMC device that works properly when mounted from Linux, but using it as a boot device does not work either. I think these two issues, booting from JTAG and programming the eMMC may be related, as I show below.
  Booting Petalinux from JTAG and programming the eMMC over JTAG, both use the ATF binary (BL31) and it seems to be that on both cases, the target apparently dies after ATF runs. At least that's the last output that's seen.
  Looking for some clues how to keep debugging this issue. Any help is appreciated.
-Pat
Petalinux boot from JTAG log, host terminal output:
[pcarr@storm linux]$ petalinux-boot --jtag --hw_server-url 192.168.1.177:3121 --u-boot
INFO: Sourcing build tools
INFO: Launching XSDB for file download and boot.
INFO: This may take a few minutes, depending on the size of your image.
rlwrap: warning: your $TERM is 'xterm-256color' but rlwrap couldn't find it in the terminfo database. Expect some problems.: Inappropriate ioctl for device
INFO: Downloading ELF file: ~/DAQ/Petalinux/DAQ16-2020.2-cfg1/images/linux/pmufw.elf to the target.
INFO: Downloading ELF file: ~/DAQ/Petalinux/DAQ16-2020.2-cfg1/images/linux/zynqmp_fsbl.elf to the target.
INFO: Loading image: ~/DAQ/Petalinux/DAQ16-2020.2-cfg1/images/linux/system.dtb at 0x01100000
INFO: Downloading ELF file: ~/DAQ/Petalinux/DAQ16-2020.2-cfg1/images/linux/u-boot.elf to the target.
INFO: Downloading ELF file: ~/DAQ/Petalinux/DAQ16-2020.2-cfg1/images/linux/bl31.elf to the target.
<No further output, as expected>
Petalinux boot from JTAG log, UART output:
Xilinx Zynq MP First Stage Boot Loader
Release 2020.2   Mar 26 2021  -  20:36:24
Reset Mode      :       System Reset
Platform: Silicon (4.0), Cluster ID 0x80000000
Running on A53-0 (64-bit) Processor, Device Name: XCZUUNKNEG
Processor Initialization Done
================= In Stage 2 ============
In JTAG Boot Mode
================= In Stage 4 ============
PM Init Success
Protection configuration applied
Exit from FSBL
NOTICE:  ATF running on XCZU39DR/silicon v4/RTL5.1 at 0xfffea000
NOTICE:  BL31: v2.2(release):xilinx_rebase_v2.2_2020.2
NOTICE:  BL31: Built : 21:21:06, Apr  7 2021
<No further output; expected U-Boot to run>
Running xsct after this boot shows the APU is running, so perhaps U-Boot is hung?:
[pcarr@storm linux]$ xsct
****** Xilinx Software Commandline Tool (XSCT) v2020.2
  **** SW Build 3064766 on Wed Nov 18 09:12:47 MST 2020
    ** Copyright 1986-2020 Xilinx, Inc. All Rights Reserved.
xsct% conn -url 192.168.1.177:3121
tcfchan#0
xsct% ta
  1  PS TAP
     2  PMU
        3  MicroBlaze PMU (Sleeping. No clock)
     4  PL
  5  PSU
     6  RPU
        7  Cortex-R5 #0 (Halted)
        8  Cortex-R5 #1 (Lock Step Mode)
     9  APU
       10  Cortex-A53 #0 (Running)
       11  Cortex-A53 #1 (Power On Reset)
       12  Cortex-A53 #2 (Power On Reset)
       13  Cortex-A53 #3 (Power On Reset)
xsct%
eMMC programming over JTAG (program_flash):
[pcarr@storm linux]$ program_flash -f BOOT.BIN -fsbl zynqmp_fsbl.elf -flash_type emmc -emmc_partition_size large -blank_check -url tcp:192.168.1.177:3121
****** Xilinx Program Flash
****** Program Flash v2020.2 (64-bit)
  **** SW Build (by xbuild) on 2020-11-18-05:13:29
Connected to hw_server @ tcp:192.168.1.177:3121
Available targets and devices:
Target 0 : jsn-JTAG-HS3-210299A8E65D
	Device 0: jsn-JTAG-HS3-210299A8E65D-147e6093-0
	Device 1: jsn-JTAG-HS3-210299A8E65D-5ba00477-0
Retrieving Flash info...
Initialization done, programming the memory
Using default mini u-boot image file - ./399521_zynqmp_emmc.bin.50Mhz
===== mrd->addr=0xFF5E0204, data=0x00000000 =====
BOOT_MODE REG = 0x0000
Downloading FSBL...
Running FSBL...
Finished running FSBL.
===== mwr->addr=0xFF18031C, data=0x64406440 =====
===== mwr->addr=0xFF180314, data=0x01150000 =====
===== mwr->addr=0xFF180318, data=0x00450043 =====
NOTICE:  ATF running on XCZUUNKN/silicon v4/RTL5.1 at 0xfffea000
NOTICE:  BL31: Secure code at 0x60000000
NOTICE:  BL31: Non secure code at 0x10000
NOTICE:  BL31: v1.3(release):
NOTICE:  BL31: Built : 10:38:42, Feb  1 2017
<No further output>
Programming eMMC from Vivado Hardware Manager:
Using default mini u-boot image file - ./.Xil/Vivado-366152-storm/zynqmp_emmc.bin.25Mhz
Downloading FSBL...
Running FSBL...
<No further output>
The programming abruptly ends with "[Labtools 27-3161] Flash Programming Unsuccessful"
Give kudos if helpful. Accept as solution if it solves your problem.
https://tuxengineering.com/blog
patocarr
  The root cause to U-Boot failing to boot was a DDR base address change introduced in 2020.1. In 2019.2, the base address was set to 0x1000000 (CONFIG_SUBSYSTEM_MEMORY_PSU_DDR_0_BANKLESS_BASEADDR) but that changed to 0x0 in 2020.1. Since the project was a port from 2019.2, this change was kept and not updated to 2020.1. There were two other related parameters that changed *BANKLESS_SIZE and *BANKLESS_KERNEL_BASEADDR. Recreating the Petalinux project from scratch highlighted the difference, and boot from JTAG was fixed.
Thanks for all your help @stephenm
-Pat
watari
Hi @patocarr
Are you using secure boot parameter ?
I guess it seems be related to secure mode on CSU.
Best regards,
patocarr
Hi @watari
  Appreciate your prompt response. I am not using secure boot, just standard (non-)security, and no isolation.
-Pat
stephenm
Can you use the --tcl script.tcl switch. For example:
petalinux-boot --jtag --hw_server-url 192.168.1.177:3121 --u-boot --tcl script.tcl
Then use XSCT to boot:
source script.tcl
You should have a better idea of what is happening here.
patocarr
Thanks for your response, @stephenm
Dumping the commands into a .tcl file and either executing it or running the commands manually doesn't show anything out of order, but still U-Boot doesn't appear to run. Here's the manual attempt from xsct:
[pcarr@storm DAQ16-2020.2-cfg1]$ xsct
xsct% connect -url 192.168.1.177:3121
tcfchan#0
xsct% targets -set -nocase -filter {name =~ "*PSU*"}
xsct% mask_write 0xFFCA0038 0x1C0 0x1C0
xsct% targets -set -nocase -filter {name =~ "*MicroBlaze PMU*"}
xsct% dow  "/home/pcarr/Work/DAQ/Petalinux/DAQ16-2020.2-cfg1/images/linux/pmufw.elf"
Downloading Program -- /home/pcarr/Work/DAQ/Petalinux/DAQ16-2020.2-cfg1/images/linux/pmufw.elf
	section, .vectors.reset: 0xffdc0000 - 0xffdc0007
	section, .vectors.sw_exception: 0xffdc0008 - 0xffdc000f
	section, .vectors.interrupt: 0xffdc0010 - 0xffdc0017
	section, .vectors.hw_exception: 0xffdc0020 - 0xffdc0027
	section, .text: 0xffdc0050 - 0xffdd0ad3
	section, .rodata: 0xffdd0ad4 - 0xffdd1df3
	section, .data: 0xffdd1df4 - 0xffdd5e5f
	section, .sdata2: 0xffdd5e60 - 0xffdd5e5f
	section, .sdata: 0xffdd5e60 - 0xffdd5e5f
	section, .sbss: 0xffdd5e60 - 0xffdd5e5f
	section, .bss: 0xffdd5e60 - 0xffdd9b8b
	section, .srdata: 0xffdd9b8c - 0xffdda4a7
	section, .stack: 0xffdda4a8 - 0xffddb4a7
	section, .xpbr_serv_ext_tbl: 0xffddf6e0 - 0xffddfadf
100%    0MB   0.2MB/s  00:00
Setting PC to Program Start Address 0xffdd0484
Successfully downloaded /home/pcarr/Work/DAQ/Petalinux/DAQ16-2020.2-cfg1/images/linux/pmufw.elf
xsct% Info: MicroBlaze PMU (target 14) Stopped at 0xffd02f24 (Stop)
xsct% con
Info: MicroBlaze PMU (target 14) Running (Sleeping. No clock)
xsct% targets -set -nocase -filter {name =~ "*APU*"}
xsct% mwr 0xffff0000 0x14000000
xsct% mask_write 0xFD1A0104 0x501 0x0
xsct% targets -set -nocase -filter {name =~ "*A53*#0"}
xsct% source /home/pcarr/Work/DAQ/Petalinux/DAQ16-2020.2-cfg1/project-spec/hw-description/psu_init.tcl
xsct% dow  "/home/pcarr/Work/DAQ/Petalinux/DAQ16-2020.2-cfg1/images/linux/zynqmp_fsbl.elf"
Downloading Program -- /home/pcarr/Work/DAQ/Petalinux/DAQ16-2020.2-cfg1/images/linux/zynqmp_fsbl.elf
	section, .text: 0xfffc0000 - 0xfffd061b
	section, .note.gnu.build-id: 0xfffd061c - 0xfffd063f
	section, .init: 0xfffd0640 - 0xfffd0673
	section, .fini: 0xfffd0680 - 0xfffd06b3
	section, .rodata: 0xfffd06c0 - 0xfffd2b1f
	section, .sys_cfg_data: 0xfffd2b40 - 0xfffd3377
	section, .mmu_tbl0: 0xfffd4000 - 0xfffd400f
	section, .mmu_tbl1: 0xfffd5000 - 0xfffd6fff
	section, .mmu_tbl2: 0xfffd7000 - 0xfffdafff
	section, .data: 0xfffdb000 - 0xfffdc1ff
	section, .sbss: 0xfffdc200 - 0xfffdc1ff
	section, .bss: 0xfffdc200 - 0xfffde73f
	section, .heap: 0xfffde740 - 0xfffdeb3f
	section, .stack: 0xfffdeb40 - 0xfffe0b3f
	section, .dup_data: 0xfffe0b40 - 0xfffe1d3f
	section, .handoff_params: 0xfffe9e00 - 0xfffe9e87
	section, .bitstream_buffer: 0xffff0040 - 0xfffffc3f
Setting PC to Program Start Address 0xfffc0000
Successfully downloaded /home/pcarr/Work/DAQ/Petalinux/DAQ16-2020.2-cfg1/images/linux/zynqmp_fsbl.elf
xsct% Info: Cortex-A53 #0 (target 10) Stopped at 0xffff0000 (External Debug Request)
xsct% con
Info: Cortex-A53 #0 (target 10) Running
xsct% after 4000; stop; catch {stop}; psu_ps_pl_isolation_removal;
Info: Cortex-A53 #0 (target 10) Stopped at 0xfffce4ec (External Debug Request)
xsct% psu_ps_pl_reset_config
xsct% dow -data  "/home/pcarr/Work/DAQ/Petalinux/DAQ16-2020.2-cfg1/images/linux/system.dtb" 0x01100000
Successfully downloaded /home/pcarr/Work/DAQ/Petalinux/DAQ16-2020.2-cfg1/images/linux/system.dtb
xsct% dow  "/home/pcarr/Work/DAQ/Petalinux/DAQ16-2020.2-cfg1/images/linux/u-boot.elf"
Downloading Program -- /home/pcarr/Work/DAQ/Petalinux/DAQ16-2020.2-cfg1/images/linux/u-boot.elf
	section, .data: 0x09000000 - 0x090f7e18
100%    0MB   0.2MB/s  00:04
Setting PC to Program Start Address 0x09000000
Successfully downloaded /home/pcarr/Work/DAQ/Petalinux/DAQ16-2020.2-cfg1/images/linux/u-boot.elf
xsct% dow  "/home/pcarr/Work/DAQ/Petalinux/DAQ16-2020.2-cfg1/images/linux/bl31.elf"
Downloading Program -- /home/pcarr/Work/DAQ/Petalinux/DAQ16-2020.2-cfg1/images/linux/bl31.elf
	section, .text: 0xfffea000 - 0xffff1fff
	section, .rodata: 0xffff2000 - 0xffff2fff
	section, .data: 0xffff3000 - 0xffff67af
	section, stacks: 0xffff67c0 - 0xffff78bf
	section, .bss: 0xffff78c0 - 0xffff865f
	section, xlat_table: 0xffff9000 - 0xffffdfff
	section, coherent_ram: 0xffffe000 - 0xffffefff
Setting PC to Program Start Address 0xfffea000
Successfully downloaded /home/pcarr/Work/DAQ/Petalinux/DAQ16-2020.2-cfg1/images/linux/bl31.elf
xsct% con
xsct%
xsct% tar
  1  PS TAP
     2  PMU
       14  MicroBlaze PMU (Sleeping. No clock)
     3  PL
  5  PSU
     6  RPU
     9  APU
       10* Cortex-A53 #0 (Running)
-Pat
stephenm
Can you change the dow address for the uboot to 0x10000 in the JTAG TCL script?
patocarr
Hi @stephenm
  Changing the U-Boot download address didn't change the outcome. This is the changed line:
dow  -data "/home/pcarr/Work/Elk/DAQ/Petalinux/DAQ16-2020.2-cfg1/images/linux/u-boot.elf" 0x10000
 I appreciate your response. Please note the BL31 output you pasted above comes from the program_flash script output. The actual non-secure address where petalinux-boot is uploading U-Boot is never shown.
-Pat
stephenm
Can you stop the processor and read the PC?
patocarr
Hi @stephenm
  Stopping the processor (A53#0) shows it's at 0x1c53844. It's not clear what's running in that location.
xsct% tar
  1  PS TAP
     2  PMU
     4  PL
  5  PSU
     6  RPU
     9  APU
xsct% tar 10
xsct% stop
Info: Cortex-A53 #0 (target 10) Stopped at 0x1c53844 (External Debug Request)
xsct% state
Stopped: (External Debug Request)
Thanks again!
-Pat
stephenm
You can do an objdump -t u-boot.elf | grep address
You can also debug the uboot in Vitis
https://forums.xilinx.com/t5/Design-and-Debug-Techniques-Blog/PetaLinux-Image-Debug-Series-Debugging-ARM-Trusted-Firmware-and/ba-p/1151076
patocarr
Hi@stephenm
  The ATF seems to be doing its job and passing control, with or without debug information, to U-Boot. The U-Boot version with symbols doesn't run from JTAG boot nor when burned and booted from QSPI (i.e. no output). The normal built U-Boot without symbols boots from QSPI but not from JTAG boot. Perhaps this bit of info may have be clue. Any suggestions how to pursue this further, other than diving into the U-Boot rabbit hole?
-Pat
stephenm
Did you change the location of the DTB? in the petalinux project? By default the uboot would expect this at 0x100000 for zynq and zynq ultrascale
However, I would expect an error here.
Anyway, it doesnt look like the uboot is hanged. Can you pass on the uboot elf? the one you used for the testing above
imok
You may have to dive into the rabbit hole...
patocarr
-Pat
