Observer noelpedro
Petalinuxv2018.3 installation Error
Hi all,
I got the error below after installing Petalinux 18.3. on Ubuntu 16.0 platform. Has anyone stumbled upon this problem?
Note: I also got similar error when attempting to install v2018.2. Also note, I have full disk encryption, Im not sure if that creates conflicts with Yocto SDK.
Please input "y" to continue to install PetaLinux in that directory?[n]y
INFO: Checking PetaLinux installer integrity...
INFO: Installing PetaLinux SDK to "/home/adleman/opt/pkg//."
INFO: Installing aarch64 Yocto SDK to "/home/adleman/opt/pkg//./components/yocto/source/aarch64"...
ERROR: Failed to install Yocto SDK for aarch64.
LOG FILE READS:
.....tar: ./sstate-cache/a6/sstate\:linux-xlnx\:zynqmp_generic-xilinx-linux\:4.14-xilinx-v2018.3+gitAUTOINC+eeab73d120\:r0\:zynqmp_generic\:3\:a638fcccf3fd9f6e1db9c88e09436dcc_populate_sysroot.tgz.siginfo: Cannot open: File name too long
tar: ./sstate-cache/a6/sstate\:linux-xlnx\:zynqmp_generic-xilinx-linux\:4.14-xilinx-v2018.3+gitAUTOINC+eeab73d120\:r0\:zynqmp_generic\:3\:a638fcccf3fd9f6e1db9c88e09436dcc_populate_sysroot.tgz: Cannot open: File name too long
.....tar: ./sstate-cache/ca/sstate\:linux-xlnx\:zynqmp_generic-xilinx-linux\:4.14-xilinx-v2018.3+gitAUTOINC+eeab73d120\:r0\:zynqmp_generic\:3\:ca89d659d0440a95ac85a878ec244796_package_write_rpm.tgz.siginfo: Cannot open: File name too long
..tar: ./sstate-cache/ca/sstate\:linux-xlnx\:zynqmp_generic-xilinx-linux\:4.14-xilinx-v2018.3+gitAUTOINC+eeab73d120\:r0\:zynqmp_generic\:3\:ca89d659d0440a95ac85a878ec244796_package_write_rpm.tgz: Cannot open: File name too long
.tar: ./sstate-cache/78/sstate\:linux-xlnx\:zynqmp_generic-xilinx-linux\:4.14-xilinx-v2018.3+gitAUTOINC+eeab73d120\:r0\:zynqmp_generic\:3\:78f9b517d3133c64696fcc55642e5f36_packagedata.tgz.siginfo: Cannot open: File name too long
tar: ./sstate-cache/78/sstate\:linux-xlnx\:zynqmp_generic-xilinx-linux\:4.14-xilinx-v2018.3+gitAUTOINC+eeab73d120\:r0\:zynqmp_generic\:3\:78f9b517d3133c64696fcc55642e5f36_packagedata.tgz: Cannot open: File name too long
.........tar: Exiting with failure status due to previous errors
Observer noelpedro
Re: Petalinuxv2018.3 installation Error
SOLVED: The reason I was receiving this error was because I had an encrypted file system mainly my home directory. I solved this issue by chaining the absolute path of the install folder to an arbitrary directory outside of home.
IE:
Initially I had: $: ./petalinux.run ~/opt/pkg
solution: $:./petalinux.run /work/pkg/petalinux_v
