jpl@xiphos.ca
Problem Building Linux with PCI for Microblaze
Gidday there,
I'm successfully building and booting linux-2.6-xlnx from git on a microblaze running on a Virtex-4.
I've enabled PCI in the kernel menuconfig and I get the following error.
... LD net/ipv4/built-in.o LD net/built-in.o LD vmlinux.o MODPOST vmlinux.o WARNING: modpost: Found 4 section mismatch(es). To see full details build your kernel with: 'make CONFIG_DEBUG_SECTION_MISMATCH=y' GEN .version CHK include/generated/compile.h UPD include/generated/compile.h CC init/version.o LD init/built-in.o LD .tmp_vmlinux1 drivers/built-in.o: In function `pci_create_sysfs_dev_files': /home/jpl/Work/ExNet/Q6/xilinx/linux-2.6-xlnx/drivers/pci/pci-sysfs.c:1061: relocation truncated to fit: R_MICROBLAZE_32_PCREL_LO against symbol `pcibios_add_platform_entries' defined in .text section in arch/microblaze/pci/built-in.o make: *** [.tmp_vmlinux1] Error 1 [jpl@elmer linux-2.6-xlnx]$
Has anyone seen this before?
Joshua
jpl@xiphos.ca
I have found the cause of the problem, but I'm not sure of the most appropriate fix.  It appears as if the microblaze compiler is not doing a good job of handling the "weak" attribute of gcc.  Within drivers/pci/pci-sysfs.c, there is a simple implementation of pcibios_add_platform_entries as follows.
int __attribute__ ((weak)) pcibios_add_platform_entries(struct pci_dev *dev)
        return 0;
According to the ((weak)) attribute, this should be overridden by 'user' code, such as the implementation provided in arch/microblaze/pci/pci-common.c.  However, something doesn't appear to handle this correctly in the mb-linux-gcc/ld as distributed by git.xilinx.com.
The current solution; comment out the pcibios_add_platform_entries function in drivers/pci/pci-sysfs.c.
At some point, I'll try to make a non-kernel example of using ((weak)) and see if this problem persists.
Joshua
jpl@xiphos.ca
I recently saw a few things updated with a 'git pull', but I'm still getting the same error with version g1743154.
Is anyone using PCI on microblaze with Linux?
jpl@xiphos.ca
        return 0;
Joshua
linnj
Yes we know that's a problem with the tools.  It's being fixed in a new version of the tools.
For now, we have hacked around the problem.
Sorry.
ltovey
John,
Can you explain the hack?  Thanks.
linnj
Seems like I just hacked out the weak was the only hack to work around it. I'm having a hard time remembering. Have you searched this forum as I think it came up before several times.
Sorry for not being more helpful.
ltovey
John,
It looks like commenting out those lines made it stop complaining.  A previous message in the thread actually said to to comment it out, I just had not read it carfully enough.  Thank you though.
I noticed that the Linux Wiki says that the PCI support is only for the PPC.  Is there any reason it won't work on a microblaze system?  This thread also seemed to talk about that also, but no one answered that part.
-L. Tovey
linnj
I don't think that Microblaze with PCI was ever completely tested at Xilinx was the issue.
I think PCI is in the mainline already as I'm sure that Petalogix is using it, and I sort of remember patches going in.
