Problem with building python-scipy in petalinux
I am trying to build scipy library for zc702 zynq platform in petalinux.  I am facing several problems.
My understading is that scipy library needs OpenBLAS and OpenBLAS needs libgfortran library. I could not build libgfortran after several days of trying.
please provide a working recipe for the python-scipy.
Best Regards,
Upendar
ihcfan
Any luck with this?
tcapuano-aps
Anything? I just posted a similar question.
ihcfan
I did make this work.  I've tried to post this, but the xilinx forum doesn't seem to take my post.
watari
Hi @ihcfan  and @tcapuano-aps
This URL might be helpful for your issue...
Would you refer it ?
https://forums.xilinx.com/t5/Embedded-Linux/Compile-Fortran-lib-a-for-Linux-under-Zynq-7000-platform/td-p/1017190
Also, let me know if you have any question.
tcapuano-aps
Thanks for the post.
It looks like fortran isn't a supported compiler form xilinx and you need to go to ones from ARM. I don't know if I am willing to jump through that hoop.
Thanks anyway.
