Programming PL from u-boot
I'm working with a Zcu102 Evaluation Board and i have installed Petalinux on it. I'm trying to program the FPGA from the u-boot like :
tftpboot ${clobstart} ${fpga_img} // Clobstart = 0x10000000 and fpga_img = design_1_wrapper.bit.bin
fpga load 0 ${clobstart} ${filesize}
The led becomes green so i think it do it successfully.
When i start linux everything is ok, but the fpga is not correctly programmed. I have programmed the fpga with : petalinux-boot --jtag --kernel --fpga, and everything works perfectly, so i suppose that when i program it on the u-boot i'm not doing it correctly.
I have tried with "fpga loadb", but it only return :
fpga - loadable FPGA image support
Usage:
fpga [operation type] [device number] [image address] [image size]
fpga operations:
  dump    [dev] [address] [size]    Load device to memory buffer
  info    [dev]            list known device information
  load    [dev] [address] [size]    Load device from memory buffer
  loadb    [dev] [address] [size]    Load device from bitstream buffer (Xilinx only)
The info of the PL device is :
U-Boot-PetaLinux> fpga info 0
Xilinx Device
Descriptor @ 0x000000006ffab1d0
Family:            ZynqMP PL
Interface type:    csu_dma configuration interface (ZynqMP)
Device Size:       1 bytes
Cookie:            0x0 (0)
Device name:       xczu9eg
Device Function Table @ 0x000000006ff7dcf8
I don't know if the filed Device Size is wrong, so it's value is 1B. In addition, petalinux create on the build a bitstream.bin file, so i dont know if i have to copy this file or design_1_wrapper.bit.
Any idea??
Tags (4)
Re: Programming PL from u-boot
See the flow here (there is a uboot flow too)
http://www.wiki.xilinx.com/FPGA+Manager+ZCU102
I did this in 2015.4 and used this command to load a bit file(not a bin)
fpga loadb 0 ${address} 0x1
 The reason the size is 0x1 is because the actually size is read from the bit file's header and I just had to provide some non-zero number for the size.
jeff
