QEMU SystemC and TLM CoSimulation
I am following the steps from http://www.wiki.xilinx.com/QEMU+SystemC+and+TLM+CoSimulation for connecting SystemC to a PetaLinux QEMU system for co-simulation.
Using Petalinux 2017.4 and ZCU102 BSP prod silicon (because i need zynq Ultrascale+ MPSoC).
But when is use the petalinux-boot command for zynqMP mentioned in the tutorial, system doesn't wait for systemC connection at all and boots through to the login prompt. And on systemC side it hangs at "attempt to listen".
Please find the attached screenshot.
Could anyone please tell me what am I doing wrong here?
Thank you,
Khalida.
Hi Khalida
It seems this issue has been resolved after manually running the QEMU instances.
Best Regards
Shabbir
Hi Khalida
Best Regards
Shabbir
