safweneful
QEMU segfault when creating the node axi dma
I am having an issue emulating my board, which is base on the zynq-700 board series. When I run qemu, it segfaults and dumps a core file, here is the backtrace.
I am using the 2017.3 tag for both the kernel and qemu. and here is my device tree.
The command I use to launch qemu:
/root/qemu/aarch64-softmmu/qemu-system-aarch64 -M arm-generic-fdt-7series -machine linux=on -serial /dev/null -serial mon:stdio -nographic -dtb dtree.dtb -kernel /root/linux-xlnx/arch/arm/boot/zImage -drive if=sd,format=raw,index=0,file=/root/rootfs/sd.img -append "root=/dev/mmcblk0 rw rootwait rootfstype=ext2"
Safwene Software engineer
shabbirk
Try adding this to the DMA node of your device tree:
sg = <&memory>;
mm2s = <&memory>;
s2mm = <&memory>;
Best Regards
Shabbir
