Visitor linux.fpga
QSPI - u-boot command
Hi Everyone,
I want to access the QSPI flash partition to check if file.txt file is on it. I want to work in u-boot. For tftp, I have command tftpboot 0x1000000 file.txt. Is there something similar for QSPI flash?
Re: QSPI - u-boot command
Hi @linux.fpga,
Here is some example.
ZynqMP> sf probe 0 0 0
SF: Detected n25q512a with page size 512 Bytes, erase size 128 KiB, total 128 MiB
ZynqMP> tftpboot 0x10000000 file.txt
ZynqMP> sf erase <QSPI-partition-address> <QSPI-partition-size>
ZynqMP> sf write 0x10000000 <QSPI-partition-address> ${filesize}
Sandeep
Visitor linux.fpga
Thanks Sandeep,
But I don't want to download file from tftpboot. I only want to check if the file file.txt exists on QSPI flash partition.
In petalinux the file file.txt is saved by the following example:
I ran mtdinfo and I checked that all partitions exist.
I created a folder /opt/temp and I mounted mtd4 on /opt/temp.
root@plnx_arm:~# mount -t jffs2 /dev/mtdblock4 /opt/temp/
In /opt/temp I created the file file.txt and I checked with command ls /opt/temp that file.txt exists.
I umounted /opt/temp.
I mounted mtd4 again and I checked the file.txt exists in /opt/temp.
After that I umounted /opt/temp and I rebooted ststem.
I stopped in u-boot and now I want to check if the file file.txt exists on QSPI flash partition.
Regards.
from u-boot prompt: " cmp " is command to check from SPI offset for your existing Image to see the data after you write into one location.
ex.
sf write 0x90000000  0x200000 <file size>
Copying file from DDR address 0x90000000 to SPI flash offset address 0x200000 of size file size in Hex.
cmp 0x200000 with file size
It prints same as what you have copied in banary format
check sf help on u-boot prompt
Thanks & Regards
Satish G
G Satish Kumar
Visitor linux.fpga
Thank you, everyone.
In the end, I decided to use fw_printenv and fw_setenv commands.
I added below line in <plnx-proj-root>/project-spec/meta-user/conf/petalinuxbsp.conf (see link https://forums.xilinx.com/t5/Embedded-Linux/How-to-include-U-Boot-s-quot-fw-printenv-quot-tool-in-Petalinux/td-p/770629).
IMAGE_INSTALL_append += " \
u-boot-fw-utils \
Instead of creating file I created environment variable in linux and than I checked in u-boot if environment variable exists.
Regards.
