Questions about the use of AXI-IIC. No device node found under / dev in the system
Hello, I encountered some problems when using axi-i2c. I refer to that wiki to configure this CONFIG_I2C_XILINX = y in the kernel, but after starting the system, there is no axi-i2c device node, kernel Is it necessary to configure other places? The device tree also has axi-i2c device tree nodes, so I don't know where it is.
