Ramdisk
Hi friends, somebody can passme the ramdisk for the ml310 board? because I downloaded the ramdisk from the wikidot and I can't run my kernel well, and the problem is on the ramdisk.
Ramdisk found in wikidot is not specific to boards. Its specific to the processor in your board. I think if your FPGA in the board has PPC then you may use this ramdisk. Btwn, what kind of problem do you have with kernel. Can you atleast the console.
