RapidIO on Petalinux
We're trying to enable the kernel support for RapidIO on Petalinux.
We tried "petalinux-config -c kernel" but RapidIO doesn't appear in the menu options.
Do we need to hack some files?
Hi @kdahlgren
Are you using v2018.1? It seems there are few RAPIDIO flags are available in kernel config.
Thanks & Regards,
Kranthi
If this post is helpful then mark this it as Accepted soultuion
Best Regards
Kranthi
Hi Kranthi - could you point us to where those flags are in the kernel config menus? We tried looking there but did not immediately see it.  If you could tip us off to where it is that would be great.
Ben
Hi @benjaminventura,
Sorry, I saw the support is only for baremetal & not for kernel. The flags which I checked was for different architecture
https://xilinx.github.io/embeddedsw.github.io/srio/doc/html/api/index.html
Best Regards
Kranthi
Hi Kranthi
Ok, so just to be clear: There is no support in Petalinux for the Linux RapidIO subsystem?
Short term we are willing to hack some files, but we need this to support our switching and endpoint IP on your platform.
Kent
