Participant perencia-wc
Reboot Fails on ZynqMP+ ZCU102 with SDCARD
I've created an image with petalinlux 2016.3. Everything works but when I try to reboot it stucks on
root@Xilinx-ZCU102-2016_3:~# reboot
The system is going down for reboot NOW!2-2016_3 (ttyPS0) (Fri Oct 13 :25:4
INIT: Sending processes the TERM signal
INI▒Stopping Dropbear SSH server: stopped /usr/sbin/dropbear (pid 1874)
dropbear.
Deconfiguring network interfaces... done.
Sending all processes the TERM signal...
[   38.134460] macb ff0e0000.ethernet eth0: link down
Sending all processes the KILL signal...
Unmounting remote filesystems...
Deactivating swap...
Unmounting local filesystems...
Rebooting... PMUFW: PmMmioWrite: (NODE_APU) addr=0xFF180358, mask=0x40000, value=0x40000
PMUFW: PmMmioWrite: (NODE_APU) addr=0xFF180314, mask=0x2000000, value=0x2000000
PMUFW: PmMmioWrite: (NODE_APU) addr=0xFF180314, mask=0x1000000, value=0x1000000
PMUFW: PmMmioWrite: (NODE_APU) addr=0xFF180314, mask=0xFF0000, value=0x150000
PMUFW: PmMmioWrite: (NODE_APU) addr=0xFF180314, mask=0x2000000, value=0x0
PMUFW: PmMmioWrite: (NODE_APU) addr=0xFF180318, mask=0x400000, value=0x400000
PMUFW: PmMmioWrite: (NODE_APU) addr=0xFF180318, mask=0x3F0000, value=0x50000
PMUFW: PmMmioWrite: (NODE_APU) addr=0xFF180358, mask=0x40000, value=0x0
[   44.790364] reboot: Restarting system
PMUFW: PmSystemShutdown: (1)
PMUFW: PmInitSuspendCb: of NODE_RPU (203, 4294967295, 0, 0)
Re: Reboot Fails on ZynqMP+ ZCU102 with SDCARD
Hi @perencia-wc
There is an AR already published for this issue AR#68514, and some older posts where the issue has been discussed. Please take a look to those ones ;)
Kind Regards,
Ibai
Ibai
Hello @ibaie, and thanks for the response :)
Unfortunately, it didn't work.
I have followed the AR#68514, but when I try to reboot it hangs.
root@Xilinx-ZCU102-2016_3:~# echo reset_assert 1114 2 > /sys/kernel/debug/zynqmp_pm/power
PMUFW: PmResetAssert▒
The board just hangs, no reset is done.
More information:
The board has ES1 silicon.
Regarding the PMUFW, as shown in booting
PMUFW: PmGetApiVersion: version 0.2
What more can I try ?
Thanks!
