Refering to GPIO pins on Device Tree
Hi everyone,
I would like to use the GPIO of the ZynqMP (on PL) to read some interrupts. These interrupts come on the EMIO pins.
In the source of the interrupts, I have to indicate the pin of the GPIO used. Something like:
interrupt-parent = <&gpio>;
interrupts = <PIN_INDEX INTR_TYPE>;
My question is: how to know the pin index?
According to UG1085, page 761:
And according to UG1087, section GPIO:
So, which index is EMIO Pin 0?
Mi ideas are:
It is 78: [0:25] is MIO, [26:51] is MIO, [52:77] is MIO [78:end] is EMIO
It is 96, because they refer to positions in the register
Does anyone know where to find the answer without having to test with a VIO if the pins go 0/1?
Thanks in advance!
Ignacio
Hi again,
since I didn't find any documentation on this problem, I tried it by implementing a design where the interrupts go just through GPIO instead of GIC. The index for the bit 0 of EMIO gpio was 78.
So, according to this, the logic should be is:
  • Bank0: [0:25]
  • Bank1: [26:51]
  • Bank2: [52:77]
  • EMIO: [78:end]
Ignacio
Hi again,
  • Bank0: [0:25]
  • Bank1: [26:51]
  • Bank2: [52:77]
  • EMIO: [78:end]
Ignacio
