Observer mishuk
Reserve a DDR memory region
Hello!
I`m using Petalinux 2017.2 with zedBoard BSP.
I reserved DDR memory region through *.dtsi file as described here: https://www.kernel.org/doc/Documentation/devicetree/bindings/reserved-memory/reserved-memory.txt
and got boot fail "rootfs image is not initramfs (write error); looks like an initrd".
The same boot fail I got when booting with "mem=" parameter.
Without "mem=" boot parameter and without memory reservation through *.dtsi file Linux boots fine.
I need help!
Tags (3)
Re: Reserve a DDR memory region
You would need to add device tree node something like this, for example, to reserve 0x2000000 of total memory 0x80000000:-
memory {
                reg = <0x0 0x0 0x0 0x80000000>;
        reserved-memory {
                #address-cells = <2>;
                #size-cells = <2>;
                ranges;
                te_linux_shm_reserved: te_linux_shm@7e000000 {
                        reg = <0x0 0x7e000000 0x0 0x2000000>;
memory {
        reserved-memory {
                #size-cells = <2>;
                ranges;
Observer mishuk
I have already done it.  Take a look at dtsi file attached
Can you try some other address for reserved memory? i.e higher 16MB
Radhey
Observer mishuk
I have tried three different addresses (low, medium and high): 0xf00000, 0x10000000, 0x1F000000.  I have 512M RAM on the board, so valid RAM addresses are 0...0x20000000.  Each time boot failure.
Observer mishuk
Your answer works.   Problems with initramfs were far away from memory reservation
