dtubbs
Run custom app at bootup at a specific priority
Greetings!
I've built a custom app under Petalinux 2019.2 and I need it to run at bootup BEFORE the network starts up.  In /etc/rc2.d (as well as runlevels 3-5) I see:
s01networking
s20myapp-init
What I need to see is:
s00myapp-init
s01networking
To try and make this happen, I've updated the myapp-init.bb file as follows:
INITSCRIPT_PARMS = "start 0 2 3 4 5 ."
However, this doesn't seem to be taking effect.  Is there something else I need to do?  Is there something I'm overlooking?
Thanks in advance for any help!
-Dave
shirilt
Hi @dtubbs
A couple of things to check:
1. Could you modify myapp-init.bb to change INITSCRIPT_PARAMS as follows:
INITSCRIPT_PARMS = "start 00 2 3 4 5 ."
If I'm not mistaken, the run-level should be specified as an integer NN (00-99), rather than N (0), which might be preventing your custom app from being placed at the start of the queue for a given init-level.
2. Could you verify that myapp-init.bb has the line "inherit update-rc.d"?. This will ensure that parameters specified in INITSCRIPT_PARAMS are passed to the update-rc.d call during installation.
dtubbs
Hi Shirilt,
Thanks for yoour suggestions!  I verified the inherit was there, and modified the parms as you suggested, but still no joy - the entry is still S20mkinterfaces-init.  Here's the whole BitBake file:
# This file is the mkinterfaces-init recipe.
SUMMARY = "Simple mkinterfaces-init application"
SECTION = "PETALINUX/apps"
LICENSE = "MIT"
LIC_FILES_CHKSUM = "file://${COMMON_LICENSE_DIR}/MIT;md5=0835ade698e0bcf8506ecda2f7b4f302"
SRC_URI = "file://mkinterfaces-init \
S = "${WORKDIR}"
FILESEXTRAPATHS_prepend := "${THISDIR}/files:"
inherit update-rc.d
INITSCRIPT_NAME = "mkinterfaces-init"
do_install() {
install -d ${D}/${sysconfdir}/init.d
install -m 0755 ${S}/mkinterfaces-init ${D}/${sysconfdir}/init.d/mkinterfaces-init
FILES_${PN} += "${sysconfdir}/*"
Any other ideas?
Thanks!
-Dave
