Newbie lukewllr1
SD card
Hi all,
First post total newbie, thanks for your patience in advance.
So I've been given a project to work on a parallella board. The SD card has already been set up before I got to it (for ethernet connection). I am now trying to make it wireless.
So I have taken another look at the SD card and I am following this thread; https://parallella.org/forums/viewtopic.php?f=48&t=1278
which led me to;
(Activate the devtmpfs)
https://elinux.org/Parallella_Speed_Up_Ubuntu#Enable_devtmpfs
I got as far as;
Edit devicetree.dts.
sudo nano devicetree.dts
(Search(Ctrl-W) and Edit the "bootargs" line then save)
bootargs = "root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait";
Compile it to dtb to enable it.
sudo dtc -I dts -O dtb -o devicetree.dtb devicetree.dts
however this gave me a syntax error. After searching around on the web I then came to this;
https://forums.xilinx.com/t5/Embedded-Linux/Device-Tree-Error-unable-to-parse-input-tree/td-p/754945
telling me to include;
/include/ "zynq-7000.dtsi"
however upon including this there was no such file directory. Sooooo I found this;
https://parallella.org/forums/viewtopic.php?f=23&t=4280
https://github.com/parallella/parabuntu ... -2016.11.1
Would this be the correct route to go down, or am I totally lost. Basically I've gone so far down the rabbit hole now I'm a bit lost. I'm sure I have said something stupid that doesn't make sense but any help would be appreciated thank you :)
Re: SD card
Hi @lukewllr1
This will create a system.dtb from system.dts file.
 dtc -I dts -O dtb -o system.dtb system.dts
This will create a system.dts from system.dtb file.
dtc -I dtb -O dts -o system.dts system.dtb
Thanks & regards
Aravind
