c.mcclenaghan
SDK debugging with Petalinux core files
Hi all
Petalinux 2015.2
SDK 2015.2
I have a Petalinux application which generates a segfault while running on my custom Zynq target board. I can generate a core file using
ulimit -c unlimited
but can't see how to connect the SDK to it either remotely via TCF or after pulling it off the target. Usually there is a "C/C++ Postmortem Debugger" debug configuration option in Eclipse but it doesn't seem to be there in the SDK.
Any help would be appreciated.
Chris
c.mcclenaghan
Will try on the Embedded Development Tools board and report back...
Chris
pvenugo
Please refer to reply in https://forums.xilinx.com/t5/Embedded-Linux/Re-SDK-debugging-with-Petalinux-core-files/td-p/724396
Praveen
hxiaoqiang
hi
  try copy your application and corefle in your host linux,and debug with arm-xilinx-linuxgnu-gdb.
 arm-xilinux-linuxgnu-gdb <your application> <core>
