samling
SDK linux app error: undefined reference to `pthread_create'
Hi All,
I'm new to linux app design.
I tried a simple thread application with SDK 2016.2. And have a error:
/main.c:33: undefined reference to `pthread_create'
Can anyone to help? Thx
Hereby the code I used FYI.
#include <iostream>
#include <cstdlib>
#include <pthread.h>
using namespace std;
#define NUM_THREADS 5
void *PrintHello(void *threadid) {
long tid;
tid = (long)threadid;
cout << "Hello World! Thread ID, " << tid << endl;
pthread_exit(NULL);
int main () {
pthread_t threads[NUM_THREADS];
int rc;
int i;
for( i=0; i < NUM_THREADS; i++ ){
cout << "main() : creating thread, " << i << endl;
rc = pthread_create(&threads[i], NULL, PrintHello, (void *)i);
if (rc){
cout << "Error:unable to create thread," << rc << endl;
exit(-1);
pthread_exit(NULL);
balkris
You can add -lpthread to the gcc command in your make file in the application.
Thanks and Regards
Balkrishan
samling
Thanks for your reply.
yes, I did added the option -lpthread .  Still have the same error.
'Invoking: ARM Linux g++ compiler'
arm-xilinx-linux-gnueabi-g++ -Wall -O0 -g3 -lpthread -c -fmessage-length=0 -MT"main.o" -MMD -MP -MF"main.d" -MT"main.o" -o "main.o" "../main.c"
../main.c: In function 'int main()':
shabbirk
Can you try this:
arm-xilinx-linux-gnueabi-gcc -Wall -O0 -g3 -lpthread -c -fmessage-length=0 -MT"main.o" -MMD -MP -MF"main.d" -MT"main.o" -o "main.o"
Shabbir
shabbirk
Hey sorry, ignore my previous response. you can try adding -lpthread in the attached path:
Right-click on application properties -> C/C++ Build -> Settings -> Tool Settings tab -> GCC C++ Linker -> Miscellaneous
joe4702
I believe you also need to link the rt library.
thiruparan
did you solve the issue,
I am using sdk 2018.2 , i am getting undefined refernce to pthread_create
i did this , still i am getting the same error any thouts
"To add this, right click on the gpio_test in Project explorer, and select C/C++ Build Properties. Under ARM Linux gcc linker  Inferred Options  Software Platform. Select the Ad symbol, and add the –lpthread option."
