SQ lite support on petalinux.
I had a concern that is SQlite DB supported for petalinux, as our application device needs to have patient records!
let me know please.
Re: SQ lite support on petalinux.
Hi sneha.chand@htic.iitm.ac.in ,
In 2019.x release version of petalinux sqlite-2.8.17 is shipped from meta-oe.
You can enable this package by adding this variable in <plnx-proj-root>/project-spec/meta-user/conf/petalinuxbsp.conf
IMAGE_INSTALL_append = " sqlite"
Sandeep
Hi Sandeep
Should have mentioned the version we are working with.
For one of the projects we are using petalinux 15.4 version, so is there any SQ lite version we can use there.
Thank you
AFAIK no we don't have any sqlite packages shipped with 15.4 petalinux, Now you have two options.
  1. You need to download sqlite source and cross compile using petalinux 15.4 toolchain.
  2. Move to newer version of petalinux or Yocto.
Sandeep
