01-22-2016 07:03 AM
I've scripted the entire processes to build new images, with 1 exception.
When my script runs the "petalinux-config --get-hw-description" command, it automatically loads a GUI to configure petalinux system settings. I dont want this GUI to pop up since im handling configuration a seperate method. I was unable to find any documentation providing details with how to 'sceltch' or skip the automatic GUI popup.
Any Ideas?
01-24-2016 04:52 AM
Good to know that you have created a script to the entire petalinux image creation flow, will you be able to share so that it helps to the other users.
I will verify if there is an option to disable the Petalinux-config GUI pop-up.
Achutha
01-25-2016 08:05 AM
Unfortunatly im not authorized to release company IP, however i feel it is reasonable to discuss the processes. Which is relativly simple, and can be found on page 5 of UG1156. These steps work for 2015.2 Petalinux.
1) I generate a petalinux project template
petalinux-create --type project --template zynq --name petalinux-project
2) If custom logic has been built in vivado, placing the .hdf file inside the new template project and running
petalinux-config --get-hw-description *** This is the step that always loads the GUI that i want to remove ***
3) Any additional system/kernel/rootfs configuration changes can be made now
petalinux-config / petalinux-config -c kernel / petalinux-config -c rootfs
4) Build the petalinux-project
petalinux-build
5) Package the built components into its associated boot image
petalinux-package --boot --fsbl /path/to/fsbl.elf --fpga /path/to/hw/bit/file --u-boot
At this point we now have a image.ub and a boot.bin that placing both of them onto an SD Card will allow the board to boot. I've glossed over some of the minor details but for the most part this is the processes that any script will run to help automate this processes.
06-01-2016 01:08 PM
The --oldconfig option will use what's already been configured will bypass the GUI, if that's what you want to do.
02-11-2019 10:23 AM
I automate this build step by piping 2 escape characters into the ncurses TUI.
echo ^e^e | petalinux-config --get-hw-description -p .
This is of course using a predefined config file
cp ../support/petalinux_config $peta_proj/project-spec/configs/config
