Second stage bootloader for zynq ultrascale
I am new to the Xilinx hardware. We are trying to implement a second stage bootloader[EL3] for
handling some specific initialization before starting uboot on cortex-a53.
- Can we boot linux without ARM Trusted Firmware? If yes what are the minimal configuration I need to take care
to start uboot from our second stage bootloader?
- It would be very helpful if I could get some references to application notes or manuals
Setup I am using:
ZCU102 development kit
Xilinx SDK
Vivado
petalinux tools
Kiran
I don’t think that is possible to boot without atf. What do you need to do that can’t be done in u-boot? It is possible the create a custom fsbl, I did something like this to load images to DDR over PCIe on a 7000. Also, I haven’t done this, but you can create a SPL u-boot image and this replace the fsbl.
Jeff
Thanks for your time!
It would have been better if we could bypass ATF.
I am not sure if I can perform my functions in Uboot which would be in EL2/EL1. I need to access few trust zone registers for security configuration before loading the low priority software stack.
However using a custom FSBL could be an option. Similar to that, using my code as secondary boot loader(at EL3) would keep the vendor provided FSBL untouched.
Kiran
