nanson
Setting of C/C++ compiler flags for compile code on Xilinx Zynq UltraScale+ MPSoC ZCU104
Previously, I used PYNQ-Z1 which equips with dual-core Cortex-A9 processor and Ubuntu 18.04. In the .bashrc, I used the following setting for compile flags.
export CXXFLAGS="$CXXFLAGS -fdiagnostics-color -Wno-psabi -mfloat-abi=hard -mfpu=vfpv3-d16 -mthumb -fPIC"
export CFLAGS="$CFLAGS -fdiagnostics-color -mfloat-abi=hard -mfpu=vfpv3-d16 -mthumb -fPIC"
However, we change the platform to Xilinx Zynq UltraScale+ MPSoC ZCU104 with quad-core ARM Cortex-A53 applications processor plus the same Ubuntu 18.04 PYNQ image. For the setting of compile flags in .bashcr, should I make any changes?
Also, I saw Raspberry Pi 3 which is Cortex-A53 uses the following compile arguments:
Raspberry Pi 3-mcpu=cortex-a53 -mfloat-abi=hard -mfpu=neon-fp-armv8 -mneon-for-64bits
Is it OK to set on the ZCU-104?
Thank you very much.
rfs613
This is somewhat of a complicated issue. You need to consider:
1) the capabilities of the hardware. It is not enough to know "Cortex-A53". This CPU core can be found many devices, with different features enabled in the core, and paired with different types of floating point co-processor. Determining exactly what you have takes some effort.
2) you also need to consider how the rest of your system was compiled, in particular, any shared libraries such as libc (glibc) and perhaps libstdc++. The code you compile will depend on (some) of these libraries, which exist in binary form on your rootfs. You need to match the compilation settings (esp floating point, even if you are not using it in your code). Otherwise your programs will likely fault upon execution.
I don't mean to dissuade you from trying to optimize compiler settings  Just be prepared to have to dig through a lot of hoops to understand the plethora of options.
nanson
@rfs613  Thank you for the comment.
I did a check and it seems that -mfloat-abi=hard -mfpu=vfpv3-d16 -mthumb are no longer supported by aarch64.
