Visitor raghup17
Splitting BOOT.BIN into its constituent files
Hi all,
Is there a tool/method I can use to split a BOOT.BIN file into its constituent elements, like the FSBL elf, bitstream, u-boot elf etc? I have a BOOT.BIN file handed down from a previous project, and was wondering if I could make minimal changes by reusing most of it. The given BOOT.BIN does not have a bitstream - it only has an FSBL elf and u-boot elf.
I want to create a new BOOT.BIN by reusing the old FSBL, adding a bitstream and reusing the old u-boot.
Raghu
Re: Splitting BOOT.BIN into its constituent files
Basically bootgen can split those images by using the -split option. But you cannot restore the original files from the boot.bin. The boot.bin does not contain elf or bit files but just binaries. IOW: Running bootgen is a lossy process. There is also a discussion going into that direction here: http://forums.xilinx.com/t5/Embedded-Linux/change-u-boot-on-flash-mtd-with-flashcp/m-p/537707/highlight/true#M11067 .
The conclusion was pretty much that it is safer to just re-generate the whole boot.bin.
