Start uboot from qspi, and then load kernel from SD card.
I am using 7Z007Sclg225, the device does not support SD card boot, I would like to start the uboot.bin from qspi , and then boot the the kernel from SD card, how do I guide it?
Re: Start uboot from qspi, and then load kernel from SD card.
You will need to create a boot image that will contain the FSBL, bit file (optional), uboot, and application (optional). You can use the create boot image GUI in SDK to do this. This is covered in the document below (Make a Linux Bootable Image for QSPI Flash):
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_3/ug1165-zynq-embedded-design-tutorial.pdf
