Still more questions on Linux I2C driver
Hello all!
I'm facing a strange problem while trying to communicate with EEPROM via PS I2C on Zedboard. I have ATC24C04 EEROM microscheme connecter to JE2 and JE3 pins of my Zedboard.
I have enabled I2C0 in Vivado, done all the procedures for building Linux. I'm using kernel from Analog Devices git.
I have added a I2C entry to .dts:
ps7_i2c_0: ps7-i2c@e0004000 {
compatible = "xlnx,ps7-i2c-1.00.a";
bus-id = <1>;
input-clk = <111111111>;
i2c-clk = <100000>;
interrupt-parent = <&gic>;
interrupts = <0 25 0>;
reg = <0x1000 0xe0004000>;
#address-cells = <1>;
#size-cells = <0>;
The design I'm using already has I2C in PL for working with soundcard and it works well. So when Linux boots I see i2c-0 and i2c-1 in /dev folder but when i do i2cdetect -l (from i2c-tools packet) this is the output I see:
i2c-0 i2c xiic-i2c I2C adapter
It not PS I2C if I understand it right. I have already looked to .config and even configured and recompiled the kernel myself but it still doesn't work. What is wrong? Do I have to write something about my EEPROM microscheme in .dts? And if yes then what do I have to write? I'm some kind of desperate.
Scholar milosoftware
Re: Still more questions on Linux I2C driver
You're missing an entry for the EEPROM, it should look like this:
            bus-id = <0>;
            clocks = <&clkc 38>;
            compatible = "cdns,i2c-r1p10";
            clock-frequency = <400000>;
            interrupts = <0 25 4>;
            reg = <0xe0004000 0x1000>;
            xlnx,has-interrupt = <0x0>;
            #size-cells = <0>;
            /* EEPROM */
            eeprom: eeprom@50 {
                compatible = "at24,24c04";
                reg = <0x50>;
"0x50" is the default address (all "a" pins grounded) for the chip.
The syntax to scan the I2C bus is:
i2cdetect 0
This will show you what's on bus i2c-0.
You'll need to enable the EEPROM driver in the kernel, then you get a file called:
            bus-id = <0>;
            #size-cells = <0>;
            /* EEPROM */
            eeprom: eeprom@50 {
                reg = <0x50>;
i2cdetect 0
/sys/bus/i2c/devices/0-0050/eeprom
You can read/write this file as if it were a local file, and the kernel will transfer it via I2C to the chip and vice versa for you.
            bus-id = <0>;
            #size-cells = <0>;
            /* EEPROM */
            eeprom: eeprom@50 {
                reg = <0x50>;
i2cdetect 0
            bus-id = <0>;
            #size-cells = <0>;
            /* EEPROM */
            eeprom: eeprom@50 {
                reg = <0x50>;
i2cdetect 0
Yes, finally that works!!!
Thank you very much!!
