SystemC/TLM modelisation of IP
Hello everybody , i am working on cosimulation , i need to konw some informayions:
-to do the Cosimulation between Ps (QEMU) and for example an Adder (PL) i want to know if these steps are right :
-Doing a design PS +PL in vivado in order to make a baremetal application so i get the app.elf to pass it to the qemu.
-Modelise My IP in systemC/TLM  ( this a question , modelise in systemC or in systemC with TLM)
-then i put adder.cc in the example systemcCosim that i follow it in wiki page
-submodel the LibsystemcTlmsoc into the systemcCosim
-and then run the PS side and SystemC side
is that right ??  One more question , picture show that IP connected from AXI slave to AXI master of systemC/tlm warapper , does that mean i can use directly my design to connect to the systemc/tlm warapper ?? if not what does they mean by this picture ??!!!
thank you a lot
hi @stephenm , can you help me please
