Anonymous
Not applicable
Test zynq702 gpio on ps
I want to test the gpio on ps for zynq702 board. I tried to follow the instructions on http://wiki.xilinx.com/osl-gpio-driver, but nothing toggles.
What's the right way to test the zynq gpio on ps?
Haibing
norman_wong
It might be that the pin you are using is not mux'ed to the GPIO controller. That is setup via the MIO registers. The registers are usually initialized by the FSBL. U-boot can change the registers but I think the code got removed in 14.2. The code was ifdef'ed out. Might be in 14.1. Last time I checked, Linux does not modify the MIO registers.
pniklas
I'm not sure which version you are using, but I'm testing the GPIO's like this:
http://wiki.xilinx.com/zc702-linux
I'm not using the Base_TRD, just plain shell
Anonymous
Not applicable
Thanks. I didn't find this link. It's helpful.
Haibing
