Nirubana
To build DPD host application using petalinux
For compiling DPD host application using petalinux, the compilation is terminated at metal/io.h. Eventhough, I have enable libmetal library in petalinux configuration.
I have attached the error image below.
hokim
Could you show your recipe file(bb file) ?
You should add build time dependency  for libmetal to your application
DEPENDS += "libmetal"
