04-29-2009 06:25 AM - edited 04-29-2009 06:30 AM
This afternoon I couldn't down the kernel from git,and I can use git to down other code from other git? Git.xilinx.com had some problem?
The message is:
Initialized empty Git repository in /home/qzy/linux-2.6-xlnx/.git/
git.xilinx.com[0: 149.199.60.181]: errno=Connection refused
fatal: unable to connect a socket (Connection refused)
04-29-2009 06:48 AM
I reset the server, sorry for the inconvenience. We're trying to move to a new server soon to help with this.
John
04-29-2009 06:48 AM
John
04-29-2009 07:06 AM
05-21-2009 10:48 PM
The server appears to be down again, I am getting the same error tonight. Thanks!
Matt
05-22-2009 06:34 AM
Sorry about that, it should be up again.
-- John
09-29-2009 06:55 PM
These days I have encountered the same questions, can you help me?
The message is:
09-29-2009 07:20 PM
09-30-2009 07:12 AM
I just reset it again and it appears fine now. Again I apologize, getting this fixed has turned into more work than it should be as I have to work with other groups to get it done.
Please bear with us as I hope a new solution will be in place soon.
John
11-25-2009 07:06 AM
The git server - 149.199.60.181 is down. I could not checkout the latest microblaze kernel using ...
git clone git://git.xilinx.com/linux-2.6-xlnx.git
11-30-2009 09:15 AM
I reset the server, sorry for the delay due to the holiday.
12-06-2009 03:14 PM
12-07-2009 10:37 AM
Sorry about that. I have asked IT to look at this as I can't seem to get the git server restarted.
12-07-2009 11:56 AM
It should be up again, sorry for the hassle. I know it's a pain and I'm pushing to try to get this solved. Appreciate the patience.
01-16-2010 05:47 PM
01-18-2010 07:19 AM
01-22-2010 12:52 AM
01-22-2010 06:01 AM
10-20-2010 04:25 AM
getting error when typing this command "git clone git://git.xilinx.com/linux-2.6-xlnx.git"
error is:
Cloning into linux-2.6-xlnx...
fatal: Unable to look up git.xilinx.com (port 9418) (Name or service not known)
can u suggest me about this
11-10-2010 06:32 AM
Did you get past this problem?
Sorry for the delay in a response. IT had taken down the server for some maintenance and I'd expect it to be working fine now.
10-30-2012 01:13 AM
Today iam trying to download the file linux-2.6-xlnx.git, but could not find it. Please let me know how can i get this file.
sanjay P
11-23-2012 11:52 AM
Dear,
I am trzing to download linux-2.6.xlnx.git from git.xilinx.com, but it does not work. Is server done or how. I need to download anzwaz mikroblaze linux kernel tonight.
regards
11-24-2012 06:14 AM
Yes, I'm seeing the same problem. I tried to ping git.xilinx.com but there's no response. Probably the server is dwon again.
11-25-2012 07:16 PM
Today, the server is down. So sad :(
11-26-2012 02:57 AM
04-05-2013 12:05 PM
No files found in the repository.
Isthe server down??
02-11-2016 09:44 PM
not able to get the download files from git clone can u rectify it
02-12-2016 07:14 AM
