Two oddities(?) with PetaLinux 2019.2 installer
A couple curiosities with PetaLinux 2019.2 installer (maybe I'm just doing something weird):
1) Installer ignores supplied destination directory -- insists you haven't supplied one and will install in current directory.
2) Installer doesn't ask for choice of architectures -- insists on installing all four.
Thoughts? Anyone else seeing this?
rday
Observer dyessgg
Re: Two oddities(?) with PetaLinux 2019.2 installer
I've seen the same thing since 2019.1.
Ah, so it's a known issue starting in 2019.1 ... I wouldn't have noticed that as I went straight from 2018.2 to 2019.2 ... both of these things seemed to work fine in 2018.2, unless I am drastically misremembering. Thanks.
rday
Observer dyessgg
That is my recollection as well.  It worked correctly in 2018.x but fails in 2019.x.  It's nowhere in the release notes, known issues or even in searches of Xilinx web site.  I can't imagine something as basic as this slipping through Xilinx's QA.  Any OOB testing would have nailed this immediately!
On the bright side 2019.2 installs MUCH faster because it doesn't sit there for minutes validating the installation file.  Good job Xilinx!
I'd like to know if there is a resolution to the first issue -- that the installer totally ignores the argument of installation directory -- as I have just joined a project, we are upgrading from 2018.2 to 2019.2, and this project incorporates an automated installation that assumes a specified install directory, so this will totally screw the automation scripts. Surely there is a fix for this, as this is a fairly significant flaw.
rday
Observer dyessgg
I don't even think Xilinx has acknowledged this as a defect/issue.  Other than the community forums, I can't find this referenced anywhere on Xilinx's website.  It's definitely not in the release notes.
I've not looked at the installer script to see if there is something funny there.
Hi @rpjday  @dyessgg
1. I am able to run the petalinux installer after specifying the directory.
Example: ./petalinux-v2019.2-final-installer.run install/
Please provide the details on how you are trying out at your end?
2. We don't have support on the choices of architecture as of this release.
Please do let me know if you have any concerns
Best Regards
Shabbir
Specifying an install location works fine on my (admittedly unsupported) Fedora 30 system; I believe I had problems on my Ubuntu  18.04.3 machine; I'll have to test that when I get back to the office.
rday
Observer dyessgg
Every time I tried installing, it ignored the path arguement.  That is until I retested again today.  I tried again from the SAME distro on Ubuntu 18.04 and both 2019.1 and 2019.2 installed correctly into the directory specified.
I'm going to try it again on my main development system this afternoon.
