U-boot MMC: 0 busy timeout
Based on the custom Zynq UltraScale+ MPSoC board, I have a problem in u-boot (xilinx-v2019.1).
I use QSPI boot, and when I try to access sd card through mmc command in u-boot command line, I saw below timeout errors.
ZynqMP > ls mmc 0
sdhci_send_command: MMC: 0 busy timeout increasing to: 200 ms. sdhci_send_command: MMC: 0 busy timeout increasing to: 400 ms. sdhci_send_command: MMC: 0 busy timeout increasing to: 800 ms. sdhci_send_command: MMC: 0 busy timeout increasing to: 1600 ms. sdhci_send_command: MMC: 0 busy timeout increasing to: 3200 ms.
sdhci_send_command: MMC: 0 busy timeout.
I have already use the patch file which provides by this forum.
https://forums.xilinx.com/t5/Embedded-Linux/sdhci-send-command-MMC-1-busy-timeout-increasing-to-400-ms/m-p/1010277#M35986
Is there any solution to solve this?
Re: U-boot MMC: 0 busy timeout
Hi @damon ,
Are you observing same error log after applying the above patches which are mentioned in forum?
Have you tried with this patch https://patchwork.ozlabs.org/patch/1118693/
Thanks & Regards
Anil B
Hi @abommera ,
Yes, the same error log after I applying this two patches.
https://patchwork.ozlabs.org/patch/1118690/
Sorry, I can not access the link you provided, can you check?
Hi @abommera,
This patch I have already used, but still have busy timeout issue.
