mowerj
UBoot Petalinux 2018.2 hard code environment
I have a situation where I will be bringing up a 7Z045 without QSPI or any other non-volatile memory (only SD card).  I have been developing on the ZC706 using Vivado/Petalinux 2018.2 and running Debian Linaro.  I've been exploring u-boot configurations, both using the default uboot as well as external sources
    petalinux-config->Linux Components Selection->u-boot->u-boot-plnx
    petalinux-config->Linux Components Selection->u-boot->ext-local-source
In the first scenario (u-boot-plnx), I've tried the following in the petalinux-config -c u-boot
    Environment->Select the location of the environment->Environment is not stored
    bootcmd value->mmcinfo; fatload mmc 0 0x10000000 image.ub; fatload mmc 0:1 0x23fff000 system.dtb; bootm
Despite specifying that the environment is not stored, I still run into the error that booti does not exist, leading me to believe that u-boot is still reading the variables on the ZC706.  I then tried using the ext-local-source, (u-boot-xlnx and checking out xilinx-v2018.2) and have been sifting around there to try other things.  I notice that changing the default_bootcmd in configs/platform-auto.h did not have an effect, either.
Any help getting to a no-environment uboot would be greatly appreciated.
aravindb
Hi @mowerj
If you would like to add your own u-boot environment variables, you can add in ./project-spec/meta-plnx-generated/recipes-bsp/u-boot/configs/platform-auto.h file.
"ram_boot= mmcinfo && fatload mmc ${sdbootdev} ${netstart} ${kernel_img} && bootm ${netstart}\0"
This will be shown in u-boot env, please run printenv in u-boot console.
The command " bootcmd value->mmcinfo; fatload mmc 0 0x10000000 image.ub; fatload mmc 0:1 0x23fff000 system.dtb; bootm " is wrong.
Thanks & regards
Aravind
aravindb
Hi @mowerj
Thanks & regards
Aravind
johnsusitronix
So easy. thank you.
For other's future reference, I redefined CONFIG_PREBOOT
_kumar
Hi @aravindb,
This information resolved my problem in mins.
