vharris007
USB boot with Linux 2015.2 build
Hi, I’m running in to a problem booting from USB with the new Linux x2015.2 build. The new build switched the ChipIdea USB driver. This driver appears to do probe deferral when loading. The problem is the USB driver isn’t online when the rootFS load is performed. I’ve tried changing the root delay, but this didn’t help. Any other ideas?
## Booting kernel from Legacy Image at 03000000 ...
   Image Name:   Linux-3.19.0-xilinx
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3617536 Bytes = 3.4 MiB
   Load Address: 00008000
   Entry Point:  00008000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 02a00000
   Booting using the fdt blob at 0x2a00000
   Loading Kernel Image ... OK
   Loading Device Tree to 1f316000, end 1f31d5f5 ... OK
Starting kernel ...
Linux version 3.19.0-xilinx (van@UbuntuGnome) (gcc version 4.8.3 20140320 (prerelease) (Sourcery CodeBench Lite 2014.05-23) ) #3 SMP PREEMPT Mon Jul 20 09:36:48 PDT 2015
Machine model: xlnx,zynq-7000
cma: Reserved 128 MiB at 0x17000000
Memory policy: Data cache writealloc
PERCPU: Embedded 9 pages/cpu @5fb97000 s8128 r8192 d20544 u36864
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 130048
Kernel command line: cma=128M coherent_pool=2M console=ttyPS1,115200 rootdelay=10 root=/dev/sda2 rw earlyprintk consoleblank=0
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 380948K/524288K available (4917K kernel code, 256K rwdata, 1712K rodata, 216K init, 208K bss, 12268K reserved, 131072K cma-reserved, 0K highmem)
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0x60800000 - 0xff000000   (2536 MB)
    lowmem  : 0x40000000 - 0x60000000   ( 512 MB)
    pkmap   : 0x3fe00000 - 0x40000000   (   2 MB)
    modules : 0x3f000000 - 0x3fe00000   (  14 MB)
      .text : 0x40008000 - 0x406817fc   (6630 kB)
      .init : 0x40682000 - 0x406b8000   ( 216 kB)
      .data : 0x406b8000 - 0x406f83a0   ( 257 kB)
       .bss : 0x406f83a0 - 0x4072c6f8   ( 209 kB)
        RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 1 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 8 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
slcr mapped to 60804000
zynq_clock_init: clkc starts at 60804100
Zynq clock init
sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 3298534883328ns
timer #0 at 60806000, irq=17
Calibrating delay loop... 1332.01 BogoMIPS (lpj=6660096)
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Setting up static identity map for 0x4a5978 - 0x4a59d0
Brought up 2 CPUs
SMP: Total of 2 processors activated (2664.03 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
DMA: preallocated 2048 KiB pool for atomic coherent allocations
cpuidle: using governor ladder
cpuidle: using governor menu
zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0x60880000
GPIO IRQ not connected
XGpio: /amba_pl/gpio@41200000: registered, base is 898
XGpio: /amba_pl/gpio@41210000: registered, base is 890
XGpio: /amba_pl/gpio@41220000: registered, base is 882
XGpio: /amba_pl/gpio@41230000: registered, base is 877
XGpio: /amba_pl/gpio@41240000: registered, base is 875
XGpio: /amba_pl/gpio@41250000: registered, base is 873
vgaarb: loaded
SCSI subsystem initialized
media: Linux media interface: v0.10
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
EDAC MC: Ver: 3.0.0
Advanced Linux Sound Architecture Driver Initialized.
Switched to clocksource arm_global_timer
TCP established hash table entries: 4096 (order: 2, 16384 bytes)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP: reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
futex hash table entries: 512 (order: 3, 32768 bytes)
jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
io scheduler noop registered
dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
dma-pl330 f8003000.dmac:        DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
xilinx-dma 80400000.dma: no channels defined
xilinx-dma 80410000.dma: no channels defined
xilinx-vdma 83000000.dma: Xilinx AXI VDMA Engine Driver Probed!!
42c00000.serial: ttyUL1 at MMIO 0x42c00000 (irq = 177, base_baud = 0) is a uartlite
e0000000.serial: ttyPS0 at MMIO 0xe0000000 (irq = 144, base_baud = 3125000) is a xuartps
e0001000.serial: ttyPS1 at MMIO 0xe0001000 (irq = 145, base_baud = 3125000) is a xuartps
console [ttyPS1] enabled
xdevcfg f8007000.devcfg: ioremap 0xf8007000 to 6083e000
[drm] Initialized drm 1.1.0 20060810
brd: module loaded
loop: module loaded
m25p80 spi32766.0: found s25fl128s, expected n25q128a11
m25p80 spi32766.0: s25fl128s (16384 Kbytes)
1 ofpart partitions found on MTD device spi32766.0
Creating 1 MTD partitions on "spi32766.0":
0x000000000000-0x000001000000 : "qspi-BOOT_bin"
CAN device driver interface
e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
e1000e: Copyright(c) 1999 - 2014 Intel Corporation.
libphy: XEMACPS mii bus: probed
xemacps e000b000.ethernet: pdev->id -1, baseaddr 0xe000b000, irq 147
xilinx_axienet 81000000.ethernet: TX_CSUM 2
xilinx_axienet 81000000.ethernet: RX_CSUM 2
libphy: Xilinx Axi Ethernet MDIO: probed
xilinx_axienet 81040000.ethernet: TX_CSUM 2
xilinx_axienet 81040000.ethernet: RX_CSUM 2
ehci-pci: EHCI PCI platform driver
e0002000.usb supply vbus not found, using dummy regulator
platform ci_hdrc.0: Driver ci_hdrc requests probe deferral
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
cdns-i2c e0004000.i2c: 400 kHz mmio e0004000 irq 141
cdns-i2c e0005000.i2c: 400 kHz mmio e0005000 irq 142
Xilinx Zynq CpuIdle Driver started
Driver 'mmcblk' needs updating - please use bus_type methods
sdhci-arasan e0101000.sdhci: No vmmc regulator found
sdhci-arasan e0101000.sdhci: No vqmmc regulator found
mmc0: SDHCI controller on e0101000.sdhci [e0101000.sdhci] using ADMA
ledtrig-cpu: registered to indicate activity on CPUs
usbhid: USB HID core driver
TCP: cubic registered
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20120528 t)
can: netlink gateway (rev 20130117) max_hops=1
zynq_pm_ioremap: no compatible node found for 'xlnx,zynq-ddrc-a05'
zynq_pm_late_init: Unable to map DDRC IO memory.
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
ALSA device list:
  No soundcards found.
Waiting 10 sec before mounting root device...
mmc0: BKOPS_EN bit is not set
mmc0: new high speed MMC card at address 0001
mmcblk0: mmc0:0001 MMC04G 3.52 GiB
mmcblk0boot0: mmc0:0001 MMC04G partition 1 16.0 MiB
mmcblk0boot1: mmc0:0001 MMC04G partition 2 16.0 MiB
mmcblk0rpmb: mmc0:0001 MMC04G partition 3 128 KiB
 mmcblk0: p1 p2
VFS: Cannot open root device "sda2" or unknown-block(0,0): error -6
Please append a correct "root=" boot option; here are the available partitions:
1f00           16384 mtdblock0  (driver?)
b300         3694592 mmcblk0  driver: mmcblk
  b301           51200 mmcblk0p1 253a9671-01
  b302         3639296 mmcblk0p2 253a9671-02
b318             128 mmcblk0rpmb  (driver?)
b310           16384 mmcblk0boot1  (driver?)
b308           16384 mmcblk0boot0  (driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
CPU1: stopping
CPU: 1 PID: 0 Comm: swapper/1 Not tainted 3.19.0-xilinx #3
Hardware name: Xilinx Zynq Platform
[<40014954>] (unwind_backtrace) from [<40010e38>] (show_stack+0x10/0x14)
[<40010e38>] (show_stack) from [<404a1230>] (dump_stack+0x90/0xdc)
[<404a1230>] (dump_stack) from [<400132f4>] (ipi_cpu_stop+0x3c/0x6c)
[<400132f4>] (ipi_cpu_stop) from [<40013900>] (handle_IPI+0x64/0x84)
[<40013900>] (handle_IPI) from [<400085cc>] (gic_handle_irq+0x54/0x5c)
[<400085cc>] (gic_handle_irq) from [<40011800>] (__irq_svc+0x40/0x74)
Exception stack(0x5f469f70 to 0x5f469fb8)
9f60:                                     9ca1ec4c 00000002 00000018 fffffff8
9f80: 9c2ba293 00000002 00000000 5fba0cc8 406f0a9c 406f0a9c 404a7f28 00000000
9fa0: 00000008 5f469fb8 4005f9d8 4039a748 80000113 ffffffff
[<40011800>] (__irq_svc) from [<4039a748>] (cpuidle_enter_state+0x4c/0xc0)
[<4039a748>] (cpuidle_enter_state) from [<40048db4>] (cpu_startup_entry+0x164/0x1ec)
[<40048db4>] (cpu_startup_entry) from [<00008664>] (0x8664)
---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
vharris007
Hi, didn't need to change the phy option. In end it was how the device tree was ordered. I modified the zynq-Zed.dts in the arch/arm/boot/dts with my pl.dtsi and other changes. When recompiled with dtc tool the usb-phy comes out on the end.
vharris007
I built the chipidea driver as outline in the Xilinx wiki, and boot with eMMC. I’m not seeing any indication the driver is functional. Has this driver ever been used before 2015.2? If so, how was it used?
milosoftware
I don't see any probe deferral in your log. Did you include the chipidea driver at all?
vharris007
Hi, it's on line:
The chipidea driver is ID as cl_hcrc. Yes, it's in the build. Attached is a copy for the .config I used.
vharris007
add attachment
milosoftware
Did you enable dummy regulators?
Maybe there's a vbus regulator in your devicetree that isn't available?
vharris007
No, didn't see the VBUS option in the devicetree
sbhatta
I see in driver probe deferral can only happen when PHY is not configured properly. Can you check driver for
phy(drivers/usb/phy-generic.c) is enabled ?
If enabled then please try with the dts attached. It is same as yours but moved PHY node from usb.
Sundeep
punnaia
Please ensure that the required  phy drivers are enabled in your config file. PFA the screen shot of the menuconfig
vharris007
tusharup
Hello vharris007,
Didn't understand what change you made, would you please explain. In my pl.dtsi, i don't have any node for usb. I am using kernel 4.0 and I also have recommended configuration for the chipidea driver.
trenz-al
kernel 4.0 is in 2015.4 and not in 2015.2 !
there is and should not be anything in pl.dtsi !!
what is needed is entry in system-top.dts
to set the usb phy and all works again..
tusharup
Yes kernel 4.0 is in 2015.4.
Originally my usb blob was like this:
usb@e0002000 {
compatible = "xlnx,zynq-usb-2.20a", "chipidea,usb2";
status = "okay";
clocks = <0x1 0x1c>;
interrupt-parent = <0x3>;
interrupts = <0x0 0x15 0x4>;
reg = <0xe0002000 0x1000>;
phy_type = "ulpi";
dr_mode = "host";
Now looking at the above post, I modified my devicetree for usb as follows:
usb@e0002000 {
status = "okay";
phy_type = "ulpi";
dr_mode = "host";
usb-phy = <0x6>;
usb_phy0: phy0 {
compatible = "usb-nop-xceive";
#phy-cells = <0x0>;
linux,phandle = <0x6>;
phandle = <0x6>;
but I got following when linux boots up.
platform e0002000.usb: Driver chipidea-usb2 requests probe deferral
Not sure why chipidea-usb2 requests probe deferral happening.
Please suggest something.
trenz-al
nono, you need only small piece in top.dts
what you need is
    usb_phy0: usb_phy@0 {
        compatible = "ulpi-phy";
        #phy-cells = <0>;
        view-port = <0x0170>;
        drv-vbus;
&usb0 {
    usb-phy = <&usb_phy0>;
NOTHING else in any devicetree files, only add this to system-top.dts
thats it.
trenz-al
ULPI transceiver vendor/product ID 0x0424/0x0007
Found SMSC USB3320 ULPI transceiver.
ULPI integrity check: passed.
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
only change in dts as in my previous post.. works!!
trenz-al
maybe you forgot to turn off OTG in linux driver config?
tusharup
I modified the usb node in the devicetree. I am not doing it right into system-top.dts file. But I have one consolidated dts file generated from 4 dts/dtsi files.
Here is my new node for usb:
usb@e0002000 {
status = "okay";
phy_type = "ulpi";
dr_mode = "host";
usb_phy0: phy0 {
#phy-cells = <0>;
drv-vbus;
Can you suggest any change in this only. Rather than changing system-top.dts file. It would be easier for me.
trenz-al
sorry no.
take petalinux 2015.4
make ONLY the changes I outlined
and it
JUST WORKS.
tusharup
I replace my kernel and devicetree with the release kerenl and devicetree, still I am getting
http://www.wiki.xilinx.com/Zynq+2015.4+Release
trenz-al
the correct download link
http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/embedded-design-tools.html
petalinux 2015.4
1 enable ulpi phy
2 disable otg
3 add the code in system-top.dts
and it should work, it works here on several different hardware platforms we have tested.
once you have petalinux working you can experiment with other options ;)
tusharup
I am getting success, my bootlog shows following.
ULPI transceiver vendor/product ID 0x0424/0x0009
Found SMSC USB334x ULPI transceiver.
but at /dev/ , I don't see the usb device. Is it something related to udev rules.
trenz-al
again if you do it with petalinux no special stuff at all
you pluging usb mem stick, it does get auto mounted. all just works. no need to mess with anything special..
tusharup
USB detection is happening and enumeration started, but got this problem.
usb 1-1: device descriptor read/64, error -71
usb 1-1: new low-speed USB device number 11 using ci_hdrc
usb 1-1: new low-speed USB device number 12 using ci_hdrc
usb 1-1: device not accepting address 12, error -71
usb 1-1: new low-speed USB device number 13 using ci_hdrc
usb 1-1: device not accepting address 13, error -71
usb usb1-port1: unable to enumerate USB device
