chrisjrh
USB2 UAS NULL pointer dereference
I can mount an external drive using USB2 and the uas driver with no issues. After a few seconds of copying a 1GB file I get the a null pointer dereference.
Steps to reproduce:
  • Attach a uas capable drive with a USB2 cable
  • Mount the disk
  • Copy a 1GB file to the disk
  • Observe the following over serial after a few seconds of transfer
Unable to handle kernel NULL pointer dereference at virtual address 00000098
[  172.373906] Mem abort info:
[  172.376688]   Exception class = DABT (current EL), IL = 32 bits
[  172.382591]   SET = 0, FnV = 0
[  172.385636]   EA = 0, S1PTW = 0
[  172.388760] Data abort info:
[  172.391625]   ISV = 0, ISS = 0x00000006
[  172.395445]   CM = 0, WnR = 0
[  172.398398] user pgtable: 4k pages, 39-bit VAs, pgd = ffffffc879dcb000
[  172.404917] [0000000000000098] *pgd=0000000879f65003, *pud=0000000879f65003, *pmd=0000000000000000
[  172.413870] Internal error: Oops: 96000006 [#1] SMP
[  172.418735] Modules linked in: nfsd lsm303d uio_pdrv_genirq xt_conntrack xt_nat iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack
[  172.435880] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.14.0 #1
[  172.442137] Hardware name: ZynqMP (DT)
[  172.446746] task: ffffff8008b21480 task.stack: ffffff8008b10000
[  172.452663] PC is at uas_stat_cmplt+0x2c/0x3a8
[  172.457097] LR is at __usb_hcd_giveback_urb+0x74/0xe8
[  172.462136] pc : [<ffffff8008622a8c>] lr : [<ffffff80085f5174>] pstate: 600001c5
[  172.469526] sp : ffffff8008003c10
[  172.472829] x29: ffffff8008003c10 x28: 0000000000000006
[  172.478133] x27: ffffff8008e8d0a0 x26: ffffffc87ab0c000
[  172.483437] x25: ffffff8008003e6c x24: 0000000000000000
[  172.488740] x23: ffffffc87ae0ec80 x22: ffffffc87a910274
[  172.494044] x21: ffffffc87b1a2810 x20: 00000000000001c0
[  172.499347] x19: ffffffc879d2e300 x18: ffffff800c0bb710
[  172.504651] x17: 6db6db6db6db6db7 x16: ffffffbf00000000
[  172.509955] x15: 0000000000004c61 x14: 0000000000000001
[  172.515258] x13: 0000000000000024 x12: 0000000000000070
[  172.520561] x11: ffffffc879d2e300 x10: ffffffc87ae0eb08
[  172.525865] x9 : ffffffc87b400358 x8 : 0000000000000000
[  172.531169] x7 : 0000000078416f80 x6 : 0000000073fff000
[  172.536472] x5 : dead000000000100 x4 : dead000000000200
[  172.541775] x3 : ffffffc879d2ba30 x2 : 00000000000007f1
[  172.547079] x1 : ffffff8008622a60 x0 : 0000000000000000
[  172.552384] Process swapper/0 (pid: 0, stack limit = 0xffffff8008b10000)
[  172.559076] Call trace:
[  172.561515] Exception stack(0xffffff8008003ad0 to 0xffffff8008003c10)
[  172.567949] 3ac0:                                   0000000000000000 ffffff8008622a60
[  172.575772] 3ae0: 00000000000007f1 ffffffc879d2ba30 dead000000000200 dead000000000100
[  172.583592] 3b00: 0000000073fff000 0000000078416f80 0000000000000000 ffffffc87b400358
[  172.591413] 3b20: ffffffc87ae0eb08 ffffffc879d2e300 0000000000000070 0000000000000024
[  172.599233] 3b40: 0000000000000001 0000000000004c61 ffffffbf00000000 6db6db6db6db6db7
[  172.607054] 3b60: ffffff800c0bb710 ffffffc879d2e300 00000000000001c0 ffffffc87b1a2810
[  172.614875] 3b80: ffffffc87a910274 ffffffc87ae0ec80 0000000000000000 ffffff8008003e6c
[  172.622696] 3ba0: ffffffc87ab0c000 ffffff8008e8d0a0 0000000000000006 ffffff8008003c10
[  172.630517] 3bc0: ffffff80085f5174 ffffff8008003c10 ffffff8008622a8c 00000000600001c5
[  172.638337] 3be0: ffffff8008003c20 ffffff80085f4ff8 0000008000000000 ffffffc87a910000
[  172.646157] 3c00: ffffff8008003c10 ffffff8008622a8c
[  172.651029] [<ffffff8008622a8c>] uas_stat_cmplt+0x2c/0x3a8
[  172.656507] [<ffffff80085f5174>] __usb_hcd_giveback_urb+0x74/0xe8
[  172.662589] [<ffffff80085f5310>] usb_hcd_giveback_urb+0x40/0xe8
[  172.668505] [<ffffff8008617ee4>] xhci_giveback_urb_in_irq.isra.26+0x8c/0xb8
[  172.675464] [<ffffff80086180d8>] xhci_td_cleanup+0xc8/0x110
[  172.681024] [<ffffff800861b954>] finish_td.isra.45+0xec/0x128
[  172.686763] [<ffffff800861c288>] xhci_irq+0x8f8/0x12c8
[  172.691895] [<ffffff80085f4e6c>] usb_hcd_irq+0x2c/0x48
[  172.697026] [<ffffff80080e5a8c>] __handle_irq_event_percpu+0x9c/0x128
[  172.703456] [<ffffff80080e5b34>] handle_irq_event_percpu+0x1c/0x58
[  172.709629] [<ffffff80080e5bb4>] handle_irq_event+0x44/0x78
[  172.715192] [<ffffff80080e981c>] handle_fasteoi_irq+0x9c/0x190
[  172.721015] [<ffffff80080e4b8c>] generic_handle_irq+0x24/0x38
[  172.726754] [<ffffff80080e520c>] __handle_domain_irq+0x5c/0xb8
[  172.732577] [<ffffff80080814c0>] gic_handle_irq+0x68/0xc8
[  172.737964] Exception stack(0xffffff8008b13d80 to 0xffffff8008b13ec0)
[  172.744398] 3d80: 0000000000000000 ffffffc87ff7ce80 0000004877474000 00000000000179ee
[  172.752220] 3da0: 0000000000000016 00ffffffffffffff 000000000a612cc7 00000000000032a0
[  172.760041] 3dc0: 000000000000143c ffffffc87ff7be84 ffffffc87ff7be64 0000000000000cfd
[  172.767861] 3de0: 071c71c71c71c71c 0000000000000024 0000000000000001 0000000000004c61
[  172.775682] 3e00: ffffffbf00000000 6db6db6db6db6db7 ffffff800c0bb710 0000002821cc74e8
[  172.783503] 3e20: ffffffc87af5ae00 0000000000000000 ffffffc87b30d000 ffffffc87b30d000
[  172.791324] 3e40: 0000002820f4fbf7 ffffff8008b21480 000000007feddaec 0000000000000400
[  172.799145] 3e60: 0000000000aa0018 ffffff8008b13ec0 ffffff8008660f58 ffffff8008b13ec0
[  172.806965] 3e80: ffffff8008660f5c 0000000060000145 ffffffc87b30d018 ffffffc87af5ae00
[  172.814786] 3ea0: ffffffffffffffff ffffffc87b30d000 ffffff8008b13ec0 ffffff8008660f5c
[  172.822608] [<ffffff80080830f0>] el1_irq+0xb0/0x140
[  172.827479] [<ffffff8008660f5c>] cpuidle_enter_state+0x154/0x200
[  172.833476] [<ffffff8008661040>] cpuidle_enter+0x18/0x20
[  172.838778] [<ffffff80080d9c00>] call_cpuidle+0x18/0x30
[  172.843997] [<ffffff80080d9e3c>] do_idle+0x19c/0x1d8
[  172.848952] [<ffffff80080d9fe0>] cpu_startup_entry+0x20/0x28
[  172.854603] [<ffffff80088335a4>] rest_init+0xac/0xb8
[  172.859557] [<ffffff8008aa0b88>] start_kernel+0x39c/0x3b0
[  172.864950] Code: b9406018 f9405800 f9403677 f9401c00 (f9404c14)
[  172.871033] ---[ end trace b27cd50f161de741 ]---
[  172.875639] Kernel panic - not syncing: Fatal exception in interrupt
[  172.881987] SMP: stopping secondary CPUs
[  172.885957] Kernel Offset: disabled
[  172.889432] CPU features: 0x002004
[  172.892823] Memory Limit: none
[  172.895864] ---[ end Kernel panic - not syncing: Fatal exception in interrupt
This happens within the uas_stat_cmplt function inside uas.c. After a few seconds of copy it gets in to a state where this function is called and cmd->device is equal to NULL, causing the above error when it executes the line:
struct uas_dev_info *devinfo = struct uas_dev_info *)cmnd->device->hostdata;
 At present I am not too sure where the device pointer becomes NULL. I have observed this on the 2018.2 and 2018.3 releases. USB3 seems to work fine, as does USB2 when using a device that uses the usb-storage driver instead of uas.
After a power cycle, I will get the following from the kernel:
usb 1-1: device descriptor read/64, error -110 (Connection timed out)
usb 1-1 new high-speed USB device number 3 using xhci-hcd
usb 1-1 new high-speed USB device number 4 using xhci-hcd
xhci-hcd xhci-hcd.0.auto: Timeout while waiting for setup device command
usb 1-1: device not accepting address 4, error -62 (Timer expired)
usb 1-1 new high-speed USB device number 5 using xhci-hcd
usb 1-1: device not accepting address 5, error -62
usb usb1-port1: unable to enumerate USB device
 The previous null pointer exception leaves the drive in a bad state that is only recoverable by unplugging the drive. Subsequent reboot's will give the above errors, only when I remove the USB cable and plug it back in will the drive appear as a storage device without these errors.
Comparing the Xilinx Linux fork against the mainline repo I came accross the following commit which suggests a hardware issue that causes issues with dwc3 and uas compatible devices:
https://github.com/Xilinx/linux-xlnx/commit/ef875d2e98b626659f7e02cdedbbb20d5865b636
Could this be linked to the above?
I would appreciate some help / advice on debugging this further.
Many thanks!
Tags (4)
chrisjrh
To add to the above I have observed the same on a ZCU102 board running the 2018.2 Petalinux release.
The device I'm using is a Delock 42488 2.5” enclosure:
https://www.delock.com/produkte/S_42488/merkmale.html
I have used a USB2 device that uses the usb-storage driver with no issues. Using the Delock with USB 3.0 and the UAS driver is fine, it's just when using a USB 2.0 cable the UAS driver encounters the NULL pointer dereference.
Has anyone successfully used a USB 2.0 device that uses the UAS driver, instead of the usb-storage (BOT) driver?
