UltraZed+ loading BIT file on-the-fly from Linux
This is a knowledge sharing post, after collecting pieces of information from various sources.
cd to your petalinux project folder (e.g. petalinux/projects/uz3eg_iocc_2017_2)
cd hw_platform
ls
>you should see your bit file here: system_wrapper.bit
>if you got a newer bit file, replace it here
>one time only: create a BIF file:
cat>fpga.bif
the_ROM_image:
system_wrapper.bit
^D
>create a bin file:
bootgen -image fpga.bif -w -process_bitstream bin -packagename xczu3eg
>copy the new generated bin file into your SD card. I'm doing it like this:
sudo cp system_wrapper.bit.bin /media/ubu2/media/sd/
>now go to the UltraZed linux shell and create a shell script for updating the FPGA with the new BIT file:
cat>bit-into-fpga.sh
echo 0 > /sys/class/fpga_manager/fpga0/flags
mkdir -p /lib/firmware
cp /media/sd/system_wrapper.bit.bin /lib/firmware/
echo system_wrapper.bit.bin > /sys/class/fpga_manager/fpga0/firmware
^D
chmod 777 bit-into-fpga.sh
>now you can
./bit-into-fpga.sh
>Remember! If you reboot the UZ, you revert back to the old BIT (assuming that the old one is still loaded by the boot loader)
>consider calling ./bit-into-fpga.sh from /etc/init.d script...
BTW, if you use an NFS filesystem, no reason for storing the BIT file in the SD card...
Enjoy!
Tags (3)
