flutnic
Ultrascale+ "FPGA fail to get the done status"
Hi all!!
I have the MYD-CZU3EG-4E4D-1200-C board from MYIR (http://www.myirtech.com/list.asp?id=613). I connect to the board via the USB to UART port and when I try to configure the PL part I always get this error: "FPGA fail to get the done status"
The commands that I execute as root are:
> cp design_1_wrapper.bin /lib/firmware
> echo design_1_wrapper.bin > /sys/class/fpga_manager/fpga0/firmware
I found that there is a "solution" in here (https://www.xilinx.com/support/answers/70504.html) but I don't understand what should I do to solve this problem. Does anybody knows a solution for this problem or can tell me what to do?
Thanks in advance
flutnic
Well, after reading carefully this: https://www.xilinx.com/support/answers/70504.html ... does it mean that I have to edit the xilfpga.c files that are installed with Vivado ? And then what? I run a new synth and implementation ?
Thanks in advance
