Ultrazed: FSBL hangs in boot up process [petalinux 2017]
I am trying to build my own boot images from my Vivado project.i am using petalinux 2017.3 and Vivado 2017.3 in Ubuntu 16.04 [64bit].
here are the steps that i followed [I am referring to UG1144 and UG1157 for the commands guide] :
>> Generate the bitstream for a simple project i.e Zynq ultrascale+ connected to gpio to LEDs.
>> Created a new petalinux project after sourcing the petalinux settings
>> Imported H/W using :
     petalinux-config --get-hw-description=/<Vivado_project>/<Vivado_prj.sdk>/<design_hw _wrapper_0>
>> Created new application inside my petalinux project : petalinux-create -t apps --name <APP_name> --enable
>> Then config the settigs via petalinux-config -c rootfs , petalinux-config -c kernel
>> Build the project : petalinux-build
- Got a warning here regarding libc.so.6[GLIBC_2.17]
>> Created package via petalinux-package --boot command and copied the BOOT.bin, image.ub files to SD card and loaded the board with boot mode  as : OFF-ON-OFF-ON [1-4]
during petalinux-config -c rootfs : i choosed my app displayed under Apps
the program is simple "hello world" print statement and all i was able to see on the COM terminal was similar to  this issue .
When i load the SD card and power on the board, the blue LED glows indicating that the FPGA is programmed. But nothing shows up on screen except for -
My image :
Not sure how to proceed from here. Any help/guidance is much appreciated.
Re: Ultrazed: FSBL hangs in boot up process [petalinux 2017]
So i am finally able to load linux successfuly via SD card after doing these :
>> petalinux-build -x clean
>> petalinux-config -c device-tree
>> petalinux-build -c device-tree
>> petalinux-build
then finally
>> petalinux-package -boot command to create BOOT.bin file
but i am still not able to get the hello world message on the terminal or find the elf / my project file compiled in the linux directories.
Attaching the boot log.
Please let me know what i need to do.
Ok i got the first issue resolved by re-configuring the build settings : build image, kernel image and rootfs image to boot from SD card.
and also exporting the hw description from project.sdk folder  and not a level down. ..
but this is what i got now :
I have tried following in this https://forums.xilinx.com/t5/Embedded-Development-Tools/Beginners-problems-with-Ultrazed-eg/td-p/800802 ... but it really didn't helped me out
Xilinx Zynq MP First Stage Boot Loader
Release 2017.3   Jan 22 2018  -  20:51:09
NOTICE:  ATF running on XCZU3EG/silicon v4/RTL5.1 at 0xfffea000, with PMU firmware
NOTICE:  BL31: Secure code at 0x0
NOTICE:  BL31: Non secure code at 0x8000000
NOTICE:  BL31: v1.3(release):f9b244b
NOTICE:  BL31: Built : 15:59:50, Jan 22 2018
U-Boot 2017.01 (Jan 22 2018 - 21:30:37 +0530) Xilinx ZynqMP ZCU102 revB
I2C:   ready
DRAM:  2 GiB
ERROR: usb dr_mode not found
at /home/vishal/myXPrj_V1/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/drivers/usb/common/common.c:32/usb_get_dr_mode()
EL Level:       EL2
Chip ID:        xczu3eg
MMC:   sdhci@ff160000: 0 (eMMC), sdhci@ff170000: 1 (SD)
zynqmp_qspi_ofdata_to_platdata: CLK 124999999
SF: Detected n25q256a with page size 512 Bytes, erase size 128 KiB, total 64 MiB
In:    serial
Out:   serial
Err:   serial
Bootmode: SD_MODE1
Net:   ZYNQ GEM: ff0e0000, phyaddr ffffffff, interface rgmii-id
eth0: ethernet@ff0e0000
U-BOOT for myXPrj_V1
ethernet@ff0e0000 Waiting for PHY auto negotiation to complete...... done
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
Retry time exceeded
Device: sdhci@ff160000
Manufacturer ID: 13
OEM: 14e
Tran Speed: 200000000
Rd Block Len: 512
MMC version 5.0
High Capacity: Yes
Capacity: 7.1 GiB
Bus Width: 8-bit
Erase Group Size: 512 KiB
HC WP Group Size: 8 MiB
User Capacity: 7.1 GiB WRREL
Boot Capacity: 16 MiB ENH
RPMB Capacity: 4 MiB ENH
reading image.ub
26582120 bytes read in 1920 ms (13.2 MiB/s)
Manufacturer ID: 13
OEM: 14e
Rd Block Len: 512
MMC version 5.0
High Capacity: Yes
Capacity: 7.1 GiB
Bus Width: 8-bit
reading system.dtb
** Unable to read file system.dtb **
ZynqMP>
>> petalinux-build
then finally
Do you have a Linux prompt?  Can you login as root?
You said that you cannot "find the elf / my project file compiled in the linux directories".  If you cannot find the binaries, you should look in
    <TMPDIR>/work/aarch64-xilinx-linux/<appname>/1.0-r0/deploy-rpms/aarch64
The executable in your running system will be at /usr/bin/<appname>.
I am working on a similar problem, but my Linux system hangs within 1-5 seconds of the login prompt being printed.
john
HI @jwmurray
There were many changes that i had to make to get the filesystem up and executed via SD card.
here's the thread that resolves the issues:
https://forums.xilinx.com/t5/Embedded-Linux/Not-able-to-mount-root-fs-during-SD-boot-in-Ultrazed-MPSoC/m-p/835504#M24575
I also had to used a custom script that i used as a linux service to execute my elf soon after login
Thank you, @vish.bh30.  My problem turned out to be a CPU idle issue.  The CPU goes into an idle state depending on the power management settings.
