Participant suppamax
Unable to configure PL from linux
I am trying to load my processor-less project on ZCU102 - without success so far.
I downloaded the linux image and boot.bin file from here.
I generated a bin file from my bitstream following this procedure.
I then copied the 3 files on the SD card an powered on the board. All fine here.
Then I ran
echo 0 > /sys/class/fpga_manager/fpga0/flags
mkdir -p /lib/firmware
cp /media/design_1_wrapper.bit.bin /lib/firmware/
echo design_1_wrapper.bit.bin > /sys/class/fpga_manager/fpga0/firmware
(as indicated here in the "Full Bitstream Using sysfs interface" section).
The error I get is
[   43.556465] fpga_manager fpga0: writing /media/har_wrap.bit.bin to Xilinx ZynqMP FPGA Manager
[   43.564977] fpga_manager fpga0: Direct firmware load for /media/har_wrap.bit.bin failed with error -2
[   43.574131] fpga_manager fpga0: Error requesting firmware /media/har_wrap.bit.bin
-sh: echo: write error: No such file or directory
How can I proceed?
Max
Re: Unable to configure PL from linux
I updated my project so that now it includes the PS.
Using the same procedure, now this is what happens
# echo ps_har_wrapper.bit.bin > /sys/class/fpga_manager/fpga0/firmware
[   90.544309] fpga_manager fpga0: writing ps_har_wrapper.bit.bin to Xilinx ZynqMP FPGA Manager
[  111.676114] INFO: rcu_sched detected stalls on CPUs/tasks:
[  111.681529]  0-...: (1 GPs behind) idle=ae2/140000000000000/0 softirq=960/961 fqs=2341
[  111.689507]  (detected by 3, t=5254 jiffies, g=238, c=237, q=0)
[  111.695409] Task dump for CPU 0:
[  111.698619] sh              R  running task        0  2439   2437 0x0000002e
[  111.705652] Call trace:
[  111.708089] [<ffffff8008085878>] __switch_to+0x98/0xb0
[  111.713205] [<ffffffc8721e87c0>] 0xffffffc8721e87c0
[  174.700110] INFO: rcu_sched detected stalls on CPUs/tasks:
[  174.705510]  0-...: (1 GPs behind) idle=ae2/140000000000000/0 softirq=960/961 fqs=9387
[  174.713493]  (detected by 1, t=21008 jiffies, g=238, c=237, q=0)
[  174.719481] Task dump for CPU 0:
[  174.722692] sh              R  running task        0  2439   2437 0x0000002e
[  174.729725] Call trace:
[  174.732157] [<ffffff8008085878>] __switch_to+0x98/0xb0
[  174.737278] [<ffffffc8721e87c0>] 0xffffffc8721e87c0
[  237.724109] INFO: rcu_sched detected stalls on CPUs/tasks:
[  237.729514]  0-...: (1 GPs behind) idle=ae2/140000000000000/0 softirq=960/961 fqs=16460
[  237.737584]  (detected by 1, t=36764 jiffies, g=238, c=237, q=0)
[  237.743572] Task dump for CPU 0:
[  237.746783] sh              R  running task        0  2439   2437 0x0000002e
[  237.753816] Call trace:
[  237.756248] [<ffffff8008085878>] __switch_to+0x98/0xb0
[  237.761369] [<ffffffc8721e87c0>] 0xffffffc8721e87c0
[  300.748108] INFO: rcu_sched detected stalls on CPUs/tasks:
[  300.753509]  0-...: (1 GPs behind) idle=ae2/140000000000000/0 softirq=960/961 fqs=23530
[  300.761580]  (detected by 1, t=52520 jiffies, g=238, c=237, q=0)
[  300.767568] Task dump for CPU 0:
[  300.770778] sh              R  running task        0  2439   2437 0x0000002e
[  300.777811] Call trace:
[  300.780243] [<ffffff8008085878>] __switch_to+0x98/0xb0
[  300.785364] [<ffffffc8721e87c0>] 0xffffffc8721e87c0
Any idea what's happening?
Voyager
Voyager
Hi @suppamax,
Did you try with cat command ?
cat ps_har_wrapper.bit.bin > /sys/class/fpga_manager/fpga0/firmware
Second option to validate the bitstream (load from u-boot) :
ZynqMP> fatload mmc 0 0x4000000 design_wrapper.bit.bin
reading design_wrapper.bit.bin
26510780 bytes read in 1749 ms (14.5 MiB/s)
ZynqMP> fpga load 0 0x4000000 $filesize
Good Luck!
Cheers,
Trigger
Loading the bitstream from u-boot works: I see the LEDs blinking as expected and if I run "boot" Linux boots correctly.
Using "cat" instead of "echo" gives an error.
Voyager
Voyager
Ok so take a look to your bitstream format -> .bit vs. .bin
Hi trigger,
could you please elaborate more on that?
I generated the bin by
1) creating a bif file like
all:
  /path/to/file.bit
2)
$ bootgen -image file.bif -arch zynqmp -process_bitstream bin
One more thing I tried is creating the image in OSL flow.
I can complete the flow, but I get a few warnings while creating the dtb
$ dtc -I dts -O dtb -o my_dts/system-top.dtb my_dts/system-top.dts
my_dts/system-top.dtb: Warning (unit_address_vs_reg): /amba_pl@0: node has a unit name, but no reg property
my_dts/system-top.dtb: Warning (unit_address_vs_reg): /memory: node has a reg or ranges property, but no unit name
my_dts/system-top.dtb: Warning (pci_device_reg): /amba/pcie@fd0e0000/legacy-interrupt-controller: missing PCI reg property
my_dts/system-top.dtb: Warning (unique_unit_address): /amba_apu@0: duplicate unit-address (also used in node /amba_pl@0)
and the itb
$ u-boot-xlnx/tools/mkimage -f fitImage.its fitImage.itb
<stdout>: Warning (unit_address_vs_reg): /images/kernel@0: node has a unit name, but no reg property
<stdout>: Warning (unit_address_vs_reg): /images/kernel@0/hash@1: node has a unit name, but no reg property
<stdout>: Warning (unit_address_vs_reg): /images/fdt@0: node has a unit name, but no reg property
<stdout>: Warning (unit_address_vs_reg): /images/fdt@0/hash@1: node has a unit name, but no reg property
<stdout>: Warning (unit_address_vs_reg): /images/ramdisk@0: node has a unit name, but no reg property
<stdout>: Warning (unit_address_vs_reg): /images/ramdisk@0/hash@1: node has a unit name, but no reg property
<stdout>: Warning (unit_address_vs_reg): /configurations/conf@1: node has a unit name, but no reg property
<stdout>: Warning (unit_address_vs_reg): /configurations/conf@1/hash@1: node has a unit name, but no reg property
<stdout>: Warning (unit_address_vs_reg): /configurations/conf@2: node has a unit name, but no reg property
<stdout>: Warning (unit_address_vs_reg): /configurations/conf@2/hash@1: node has a unit name, but no reg property
Then, when I power the board on
[    4.591376] VFS: Cannot open root device "(null)" or unknown-block(0,0): error -6
[    4.598785] Please append a correct "root=" boot option; here are the available partitions:
[    4.607117] 0100           65536 ram0
[    4.607119]  (driver?)
[    4.613185] 0101           65536 ram1
[    4.613187]  (driver?)
[    4.619257] 0102           65536 ram2
[    4.619259]  (driver?)
[    4.625338] 0103           65536 ram3
[    4.625340]  (driver?)
[    4.631409] 0104           65536 ram4
[    4.631411]  (driver?)
[    4.637490] 0105           65536 ram5
[    4.637491]  (driver?)
[    4.643565] 0106           65536 ram6
[    4.643567]  (driver?)
[    4.649642] 0107           65536 ram7
[    4.649644]  (driver?)
[    4.655718] 0108           65536 ram8
[    4.655719]  (driver?)
[    4.661794] 0109           65536 ram9
[    4.661797]  (driver?)
[    4.667870] 010a           65536 ram10
[    4.667872]  (driver?)
[    4.674028] 010b           65536 ram11
[    4.674030]  (driver?)
[    4.680196] 010c           65536 ram12
[    4.680197]  (driver?)
[    4.686354] 010d           65536 ram13
[    4.686355]  (driver?)
[    4.692521] 010e           65536 ram14
[    4.692523]  (driver?)
[    4.698680] 010f           65536 ram15
[    4.698681]  (driver?)
[    4.704851] b300        15558144 mmcblk0
[    4.704853]  driver: mmcblk
[    4.711618]   b301          204800 mmcblk0p1 1d3f1026-01
[    4.711620]
[    4.718383]   b302        15352320 mmcblk0p2 1d3f1026-02
[    4.718385]
[    4.725154] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[    4.733404] CPU: 3 PID: 1 Comm: swapper/0 Not tainted 4.14.0 #3
[    4.739301] Hardware name: xlnx,zynqmp (DT)
[    4.743467] Call trace:
[    4.745904] [<ffffff8008088ae8>] dump_backtrace+0x0/0x360
[    4.751283] [<ffffff8008088e5c>] show_stack+0x14/0x20
[    4.756318] [<ffffff80089cd1a0>] dump_stack+0x9c/0xbc
[    4.761352] [<ffffff800809af98>] panic+0x11c/0x274
[    4.766126] [<ffffff8008d01124>] mount_block_root+0x1a8/0x27c
[    4.771854] [<ffffff8008d01430>] mount_root+0x11c/0x134
[    4.777062] [<ffffff8008d015b4>] prepare_namespace+0x16c/0x1b4
[    4.782878] [<ffffff8008d00d44>] kernel_init_freeable+0x1b8/0x1d8
[    4.788955] [<ffffff80089df0f0>] kernel_init+0x10/0x100
[    4.794162] [<ffffff8008084a60>] ret_from_fork+0x10/0x18
[    4.799456] SMP: stopping secondary CPUs
[    4.803361] Kernel Offset: disabled
[    4.806832] CPU features: 0x002004
[    4.810216] Memory Limit: none
[    4.813258] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
but I see the bitfile has been loaded as the leds are correctly driven by PL.
It was the ramdisk missing.
Voyager
Voyager
And ?
Problem solved or not ?
No, I still cannot reconfigure the PL from PS.
But I will stop debugging this problem as it's not the best solution for my problem.
I'll try to reconfigure the PL via some configuration registers accessible from PS.
