galenthas
Updating Existing Recipe from Another Branch
I am following the petalinux flow using petalinux ver 2019.1.
Currently this release is packed with VLC version 2.2.2 from meta-openembedded thud branch.
I need to update VLC to 3.x version. I tried cloning the warrior branch for this specific recipe but the tools didn't let me add this user layer as it is not compatible with thud.
How can I update VLC from another recipe?
Best Regards.
Mustafa
koog1000
I had a similar issue with Gunicorn, Petalinux includes version 19.1.1, which is 6 years old and only used for python2. What I had to do was to create a valid recipe and then place it in meta-user layer (./project/spec/meta-user/recipes-apps) and then in the layer.conf of the meta-user layer I added the PREFFERED_VERSION for  my gunicorn recipe.
Your meta-user layer should look something like this:
meta-user
├── conf
│   ├── layer.conf
│   ├── petalinuxbsp.conf
│   └── user-rootfsconfig
├── COPYING.MIT
├── README
├── recipes-apps
   └── vlc
   ├── vlc_<version>.bb
   └── README
and layer.conf should have a line similar to:
PREFERRED_VERSION_vlc = "<version>"
@koog1000
Thank you.
Could you share the contents of the files
  • vlc_<version>.bb
  • layer.conf
  • petalinuxbsp.conf
  • user-rootfsconfig
or the required modifications as a reference?
koog1000
All of those files, except the vlc bitbake recipe, are auto generated by the petalinux project. I can't tell you what would go in the vlc bitbake recipe because I never made one (If you read my previous post, I made a recipe to include a new version of gunicorn, not vlc). If I were to make a recipe for vlc, I would start by looking at an existing bitbake recipe for vlc:
http://cgit.openembedded.org/meta-openembedded/tree/meta-multimedia/recipes-multimedia/vlc/vlc_3.0.11.bb?h=master
Other than that you need to add a line to the layer.conf as called out in my previous post.
koog1000
It looks ok to me. I would try cleaning your build and rebuilding. From there I would try explicitly putting the chrony subfolder into the chrony bitbake script.
