Upload .bit file to FPGA from APU running Petalinux 2018.3
I want to upload a .bit file I have create from Vivado 2018.3 into ZUC102 FPGA. The problem is that I want to do that from APU that running Petalinux 2018.3 on the same board but I don't know if it's possible because I haven't find any documentation. Do you have any suggestions?
Tags (4)
Re: Upload .bit file to FPGA from APU running Petalinux 2018.3
HI @p8grs
Please refer this below links for loading the bitfile to FPGA from u-boot & Linux.
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842056/FPGA+Manager+ZCU102
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841847/Solution+ZynqMP+PL+Programming#SolutionZynqMPPLProgramming-FPGAprogrammingusingsysfsattributes
Thanks & eragrds
Aarivnd
HI @p8grs
Thanks & eragrds
Aarivnd
Hello aravindb,
Thank you very much, that's what I needed!!
