Use MDIO clause 45 on Zynq
We have a custom FMC card with an Marvell 88Q2112 Single Pair Ethernet Phy, which is configurable via MDIO. Unlike most phy only understands clause 45 MDIO.
I build my Image with Yocto and already tried several Kernels 4.14 and 4.19. Xilinx-Rebase in both cases. I read that MDIO clause 45 has to be supported by the MDIO driver and the mac driver, that's why i tried to apply a patch for supporting Clause 45 in macb driver. (https://lore.kernel.org/patchwork/project/lkml/list/?submitter=25241).
Are there any other points I'll have to check?
The phy is connected to ethernet1 via the gmii2rgmii IP from xilinx. However, I don't even know if this IP is able to handle Clause 45 MDIO communication correctly, because the IP is on the same bus.
I tried several variants of the devicetree, always with the compatible = "ethernet-phy-ieee802.3-c45". I tried to put the phy node directly into the ethernet node and to create a seperate mdio bus, together with the gmii2rgmii IP.
I'm looking forward for every suggestion!
Best Regards
Franz
